odometer broken.....
Old Feb 18, 2014 | 03:28 PM
yotie's Avatar
so my odometer on my 1997 4runner 4x4 stopped tunning at 112999... trip doesn't reset,, stuck on "zero"..... but my "MPH" needle is fine,,, anyone know what the problem is,, maybe a link showinmg how to fix,, thank you
Old Feb 19, 2014 | 05:48 AM
Jomoka's Avatar
The ODO did that on my wife's '96, at around 175K miles. She used to reset the trip ODO on each fill-up. Eventually the trip reset button got a little flaky and sort of disabled the trip and main ODO for a couple of hundred miles. Tried fidgeting with it a little, eventually it started working again on its own, and she just doesn't touch that trip reset any more.
I know that's not really any help, since nothing was 'fixed'. I'm assuming something just gets sticky inside, and the reset mechanism doesn't spring back properly.
Old Feb 19, 2014 | 08:16 AM
yotie's Avatar
yeah i was thinking maybe it's stuck ,, but not sure how to go about taking it apart,, im mechanically inclined but i like to do as much research as possible,, was maybe seeing if someone can link a video aor photo's on taking the dash and cluster apart,, i'v looked and cant seem to find someone taking apart a 3rd gen runner,,,
Old Feb 19, 2014 | 09:23 AM
reaj's Avatar
96 at 257 and mine are still turning however check eBay and part yards gauge clusters aren't usually that expensive just try the match the mileage up.
Old May 22, 2014 | 03:01 AM
SnowRunner98's Avatar
on my 98, I take it down a dirt road, hit a wash board or bump. Then I have RPM's and no speed. Stop, turn off truck and start again. Boom it works. Wierdest thing ever. Whats up with that?
Old May 22, 2014 | 03:18 AM
habanero's Avatar
For the op:
post 1854 should get you started. Pictures!
https://www.yotatech.com/forums/f200...1/index93.html
Bad speed sensor? Speed sensor hitting ring in rear? Bad connection?
I don't have the front abs sensors (also speed unless you don't have abs, then it's on the transfer case) and mine does the same thing on certain bumps, though I only have to slow down to around 10 or 20mph or so for it to kick back on.
Old Feb 10, 2015 | 09:13 AM
irish_tyrant's Avatar
Hey Yotie,
Did you ever get this sorted out? I had the same issue where I hit the trip reset and it made the odometer stop working. I took the dash apart yesterday but could not find any broken components. It looks like it should all be engaged with the drive motor.
Thanks
Old Feb 10, 2015 | 02:58 PM
habanero's Avatar
IT: did you check out my pics on post 1854 of my build thread as mentioned above? The break on mine was not obvious...at first I thought it was fine....pic#2 was the best picture I could get of it.
Old Feb 10, 2015 | 06:32 PM
Ya, I pulled mine apart and couldn't see any breaks. The reset button/swing mechanism seemed to be working fine. I couldn't see anywhere where it may be jammed.
Do you know where to apply power to see if it will spin on the bench?
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
FRANCOARMANI
Oct 9, 2015 01:27 PM
mulewright
Oct 3, 2015 02:47 PM
matt1833
Sep 16, 2015 07:11 AM
TammyMarie
Jul 15, 2015 11:14 AM
