Matters Light
Old May 8, 2014 | 04:31 PM
CfTacoma's Avatar
Battery Light
I took my truck to a local battery shop and had my battery tested. Test said I needed to replace my battery. Replaced battery and the light won't turn off.
Truck is a 1999 SR5, 4x4, v6
Old May 8, 2014 | 04:39 PM
CJM's Avatar
CJM
Check voltage across terminals with truck off should be at least 12v, truck on should be at least 13.5v or better.
Old May 8, 2014 | 04:42 PM
vital22re's Avatar
totally a bro
whats the alternator putting out voltage wise?
Old May 8, 2014 | 05:13 PM
CfTacoma's Avatar
I don't have the paper anymore but it said like 12.7 or 13.7 somewhere in there Thinking maybe mudding I loosened a connection?
Old May 8, 2014 | 11:31 PM
wyoming9's Avatar
Red face
What started this whole thing??
Your charge light came on after playing in the mud is that what happened??
Then you were told you needed a battery why??
Then you bought a new battery and your still the same place??
Old May 9, 2014 | 04:02 AM
blake.nemitz's Avatar
sounds like your alt brushes are dusted. if you were not charging it wasnt the battery. you should be at 14 for running or close to it and 12.6 with engine off on a full charge. try thumping the alternator with the handle of your hammer with the engine running and see if the light goes off most of the time this will jar them enough to make a little contact. if it does its the brushes and are like 2 dollars to replace parts wise.
Old May 9, 2014 | 04:26 AM
CfTacoma's Avatar
What happened was I had ran the battery down a little bit listening to radio with the truck off. Then the light came on maybe an hour later and was just on when I was idle. Took it to shop had it tested said it needed new battery and after my other completely died and had to be jumped I jumped the gun and got the new battery. Now that light won't turn off at all. I'll go try the hammer thing
Old May 9, 2014 | 05:26 AM
HighLux's Avatar
ever consider just getting the alternator tested?
Old May 9, 2014 | 07:03 AM
dropzone's Avatar
Fossilized
We have a winner....
Well a few.
Alternator should have been tested by the battery place...I would do business elsewhere. .
Old May 9, 2014 | 07:13 AM
HighLux's Avatar
Well a few.
Im a winner. Im using that all day.
Old May 9, 2014 | 07:54 AM
vital22re's Avatar
totally a bro
Sometimes alternators and batteries fail together. Seen it a hand full of times. Once on an old honda and the rest were domestics.
Old May 9, 2014 | 08:01 AM
CfTacoma's Avatar
Started truck and disconnected the battery and it died. So it's the alternator. Checking one last connection and if that ain't it gunna have to replace it </3
Old May 9, 2014 | 10:48 AM
wyoming9's Avatar
Red face
Removing the battery cable with an engine running is just plain dumb.
But if that is your thing go for it.
Because with a cable disconnected from the battery you no longer have a complete circuit.
No voltage to excite the alternator
Old May 9, 2014 | 12:00 PM
94 Newbie's Avatar
Lightbulb That is an old trick.
A blurb on it here : http://www.ehow.com/how_7537506_test...r-battery.html
As they mention, not a good plan on newer, computer controlled vehicles. But, it is a 'tool' I have heard of in the past.
FYI -
Britt
Old May 9, 2014 | 01:29 PM
CfTacoma's Avatar
Well it worked and fixed it haha. Bad connection in the back of the alternator
AkitaDog
Sep 1, 2015 08:05 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
PopsDad1
Jul 30, 2015 02:21 PM
trucker trash
Jul 28, 2015 10:09 AM
Michael oaks
Jul 27, 2015 11:47 AM
