drive shaft wobble
Old Mar 13, 2014 | 09:22 PM
vegasrunner's Avatar
drive shaft wobble
99 runner 4x4 at. So I inspected the drive shaft am I able to repair the double cardon? I replaced the rear u joint and I still have vibration around 65mph and while coasting. The slip joint seemed ok and I greased it and the joints. What should I do? I heard you cannot fix the ujoints next the card on is this correct?
Old Mar 13, 2014 | 09:41 PM
dropzone's Avatar
Fossilized
also check your T/C output and your rear pinion for play
Old Mar 13, 2014 | 11:00 PM
they look like they have play but not sure and if play in them replace the bearings? I had the same problem with my 92 runner and where would I buy the case output bearing and rear diff input bearing? And can I replace the cardon joints with the same u joint I got for the rear at autozone? I know there are many many many threads about drive shaft wobble but everyone's are different it's fine from 0 to 50mph on and off gas and coasting in neutral but above 50mph I feel it most at 65 or 70 but at 85 it's gone til I let off gas and slight rumble for a second and its all smooth but at 65thru85 on freeway in neutral pure nonstop rumble and downhill in neutral is the same way at 60ish when I replaced rear joint the joint needles were pure rusted powder and once installed smoother then it was I couldn't go above 45 without it rumbling
Old Sep 9, 2014 | 09:33 AM
well to let everyone know for an update: driveshaft bent and double cardone joint is worn out and transmission mount is shot as well automotix.com has a driveshaft for about 100 used with warranty
Old Sep 9, 2014 | 09:37 AM
ShouldaWornGloves's Avatar
I was gonna mention the possibility of a bent shaft. Sounds like you gotit covered. Good Luck!
Old Mar 1, 2015 | 06:15 AM
Whitfield's Avatar
Forget that I'm searching and then try to respond to an old post...
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
Old Mar 1, 2015 | 12:54 PM
Teuf's Avatar
Driveshaft and pinion angles matter. The set up has to be very close to these 2. When I lifted my truck I had probs, solved with proper pinion angle.
Old Mar 1, 2015 | 12:56 PM
Teuf's Avatar
My last cure. 6 degree shims.
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
