2000 Tacoma ADD axle Dust covers??
Old Apr 6, 2014 | 05:39 AM
wyoming9's Avatar
Red face 2000 Tacoma ADD axle Dust covers??
Being it is Sunday of course my Big feet managed to step on this cover and bend it. 2000 Tacoma ADD grease/ Dirt Cap on the front axle
Does any one know if other than The Dealer or used is there any other source for new.
Are the 4Runners the same?? Other vehicles that will swap??
I checked Napa Pro Link and ebay with no luck .
Even a Goggle search only brought up dealer web sites.
At least it is always the little things.
Thanks
Old Apr 6, 2014 | 07:33 AM
rworegon's Avatar
Dealer or used is the only place I've found 'em.
Can you straighten out the bent area?
Old Apr 6, 2014 | 10:48 AM
wyoming9's Avatar
Red face
That was kinda what I had thought.
I have it straight enough to get it back on but the first pot hole it could be gone.
I will be calling my dealer it in the morning.
Thanks for confirming my thoughts
Old Apr 6, 2014 | 11:00 AM
TheDurk's Avatar
This puppy?
Part 41252-35030 (DEFLECTOR, DUST (FOR FRONT DIFFERENTIAL)) was found on the following models:
Date range Model Frames/Options Found in diagram
11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* 43-01: FRONT AXLE HOUSING & DIFFERENTIAL
01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 43-01: FRONT AXLE HOUSING & DIFFERENTIAL
02/1999-09/2006 TOYOTA TUNDRA GSK30,UCK3*,4*,VCK30,40 43-01: FRONT AXLE HOUSING & DIFFERENTIAL
09/2000-10/2007 TOYOTA SEQUOIA UCK35,45 43-01: FRONT AXLE HOUSING & DIFFERENTIAL
Old Apr 6, 2014 | 01:44 PM
wyoming9's Avatar
Red face
No the one on the outside where the Free wheel hub would be if it was not ADD
The cover over the nut holding the CV axle in.
I am sure if I had to use it I could everything looks pretty tight .
My luck will get a spring Blizzard the salt will get in the bearing the bearing will collapse on the Cross Bronx at rush Hour!!!
Old Apr 6, 2014 | 04:58 PM
TheDurk's Avatar
Gotchya. Called a Front Hub Grease Cap. Yes, same as 4Runner and several others:
Part 43514-28010 (CAP, FRONT HUB GREASE) was found on the following models:
01/1990-06/1997 TOYOTA PREVIA TCR1*,2* 43-03: FRONT AXLE HUB
01/2006- TOYOTA FJ CRUISER GSJ1* 43-03: FRONT AXLE HUB
11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* 43-03: FRONT AXLE HUB
08/2002-07/2009 TOYOTA 4RUNNER GRN21*,UZN21* 43-03: FRONT AXLE HUB
08/2009- TOYOTA 4RUNNER GRN28*,TRN28* 43-03: FRONT AXLE HUB
01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 43-03: FRONT AXLE HUB
09/2004- TOYOTA TACOMA GRN2**,TRN2** 43-03: FRONT AXLE HUB
11/2002-07/2009 LEXUS GX470 UZJ120 43-03: FRONT AXLE HUB
11/2009- LEXUS GX460 URJ150 43-03: FRONT AXLE HUB
02/1999-09/2006 TOYOTA TUNDRA GSK30,UCK3*,4*,VCK30,40 43-03: FRONT AXLE HUB
09/2000-10/2007 TOYOTA SEQUOIA UCK35,45 43-03: FRONT AXLE HUB
©2014 ToyoDIY
Toyota Only as far as I can find.
Old Apr 6, 2014 | 11:23 PM
wyoming9's Avatar
Red face
Thank You !!
Old Apr 18, 2014 | 03:48 PM
wyoming9's Avatar
Red face
The story of my life Yard ones were quoted Higher than brand new ones .
When I told the yard person this they laughed and walked away.
No wonder I really hate used parts.
smthwsn357
May 1, 2024 07:28 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
