Rebuilding 3.4
Old Jun 2, 2014 | 11:46 AM
Machtac's Avatar
Rebuilding 3.4
Just bought a 99 taco with 205k on the dash. My plan is to build a nice off-roader that handles the highway nicely. I want to eventually lift it and stuff 35's under it. First of business will be to pep the engine back up to make it safe. I want to pull the engine and put some new internals in to keep it from blowin on me with over 200k miles. Then I want to slap a TRD supercharger/intake/exhaust on it. My question is..what should I do to the engine to keep it bulletproof? I would like to have the engine built and supercharger ordered or installed and tuned by September˟
Im new to yotas and the 3.4l so I dont know its weak spots or what is normally needed with so many miles
Old Jun 2, 2014 | 11:48 AM
JasonYota's Avatar
You would probably be just fine doing a regular tune up and change the timing belt and water pump.
Old Jun 2, 2014 | 03:26 PM
Machtac's Avatar
So the internals should be able to handle the extra power that the supercharger dishes out?
Old Jun 2, 2014 | 03:37 PM
JasonYota's Avatar
I would imagine since some come stock with the supercharger.
Old Jun 2, 2014 | 03:41 PM
Machtac's Avatar
Wow, didn't know that..
I guess i'm just worried because of the 200k miles...but "if it ain't broke, don't fix it," right?
Old Jun 2, 2014 | 03:48 PM
JasonYota's Avatar
Probably the supercharger your were going to order is a factory one. If you've researched them yet
Old Jun 2, 2014 | 04:49 PM
Machtac's Avatar
Yes I have done some research. It will be a TRD OEM supercharger. I will also be getting the URD 7th injector kit for the fuel upgrade to help with pinging. Then a 2.2 pulley i believe is another recommendation. I'm not sure what the "IPT Valve body upgrade" is though? Is that only for automatic tranny's?
Old Jun 3, 2014 | 02:44 AM
Texas_Ace's Avatar
Yes, leave the engine alone, they regularly turn 300k-400k miles. They are tanks that refuse to die. They will also take a TON of abuse, more then the wimpy TRD superchaerger can put out thats for sure.
If you want some real power/performance go turbo.
The stock engine is good to north of 400whp, how far north depends on how you are tuning it and whats making the power.
Old Jun 3, 2014 | 04:19 AM
Jomoka's Avatar
If you were really going to go wild with boost, you'd probably want some H-beam rods and forged pistons. And a cam.
But really, all you really need to do is a t-belt/wp unless it's had one recently.
The good thing about thrashing a bone stock engine is that if you blow it up, another one is really cheap and easy to find. Blowing up a $$$$ set of custom rods and pistons really hurts.
Old Jun 9, 2014 | 07:51 AM
BlazeRunner's Avatar
How to keep the 3.4 bulletproof?
Maintain it.
Jayboy74
10
Dec 21, 2021 08:27 AM
pplusent
Sep 18, 2018 10:02 PM
coleypull15
Nov 3, 2015 07:41 AM
93toyoguy
Aug 31, 2015 08:02 AM
ashersullivan88yota
Aug 19, 2015 06:00 PM
