overheating/electrical issue
Old Mar 21, 2014 | 06:23 PM
chickenhammer's Avatar
So I have a 96 Tacoma 4x4 with a 99 3.4 in it few weeks ago it got hot so I replaced thermostat, water pump, timing belt, all tensioner pulleys an all that and after all that the temp gauge still goes all the way to just before the red within 3-5 minutes regardless of outside temp. Before I changed water pump the heat would get hot and then cold hot then cold, after k changed it the heat stays nice and hot? Is the temp gauge bad or the sender unit?
Old Mar 21, 2014 | 07:18 PM
TheDurk's Avatar
Did you bleed the system and get all the air out?
Old Mar 21, 2014 | 07:22 PM
Nope I didnt, isn't that what the jiggle valve on the t stat is supposed to do? Anyway how do you bleed the system?
Old Mar 21, 2014 | 07:50 PM
DailyDrive's Avatar
You need to measure the temperature independently of everything else. You need to measure it with something reliable. The gauge on the panel is not for troubleshooting gauge problems!
Old Mar 21, 2014 | 08:10 PM
I have an infared temp gun, is that a reliable enough way? Or are you referring to a different method?
Old Mar 21, 2014 | 08:23 PM
TheDurk's Avatar
That's your problem. Jiggle valve HELPS, it doesn't do it all by itself.
1. Heater on HIGH (front and rear, if so equipped).
2. Park facing up hill on mild grade or put front wheels on a curb.
3. Fill radiator and fill reservoir to MAX.
3. Leave rad cap off.
4. Start engine and allow engine to heat until thermostat opens--you will see coolant start to circulate in rad.
5. You will see bubbles escape from rad. After several minutes, bubbles will stop coming out.
6. Turn off engine, allow to cool.
7. Fill rad, replace cap.
8. Fill reservoir to MAX.
9. Take for a drive of at least 20 minutes. Allow to cool. Check coolant in reservoir and add coolant to MAX if needed. Or just use as normal and check the next morning when engine is cool.
Old Mar 22, 2014 | 08:02 AM
So I did this and nothing happened, and temp gauge did its normal thing, bad radiator? Head gaskets?
Old Mar 22, 2014 | 02:19 PM
wyoming9's Avatar
Red face
What is happening in the radiator?? Do you have big areas with no flow that are blocked??
Is the coolant getting hot ?? Just the gauge?
I never had the issues with the 3.4 like the 22REC for air pockets.
Did you get the thermostat in upside down?? Easy to do
Just how hot did it get??
Why did it get Hot??
Old Mar 22, 2014 | 02:37 PM
I have no idea why it got hot, that's what I'm trying to figure out, the gauge was holding right under the red area, didn't go into the red at all, I put the jiggle valve at 6 o clock, lower rad hose is warm and top hose is hot, top of rad hot also, I followed the steps above for burping the radiator and no bubbles ever came out, I let it sit there and run for 20 minutes and nothing happened
Old Mar 22, 2014 | 05:03 PM
So no idea what I did wrong the first time but I tried burping the radiator again and a lot of bubbles came out for about 5 minutes but the dumb gauge is still going to the same mark, previous owner did some wiring behind the dash any chance the needle got messed with and that's what this problem is?
Old Mar 22, 2014 | 05:56 PM
TheDurk's Avatar
I would recommend a live scanner or ScanGuage that can poll temp from the ECU. Different sensor than the gauge and more accurate than gauge or IR thermometer.
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
