96 4runner 3.4 won't start
Old Feb 9, 2014 | 05:42 AM
webmailjoe's Avatar
Unhappy 96 4runner 3.4 won't start
Ok I will start at what happen. Went out to start the 4runner and it would crank and fire and shut off. So thinking it might have flooded left it until the even and tried it again the same thing but getting worse as not firing at all. Shoot starting fluid in intake would fire then shut off. So replace the fuel pump and filter and now have fuel pressure, but still will not start. This is were I am stuck. I have fuel pressure, spark, and the timing is correct all marks line up. I do not have a compression check tool. There are no codes. Were do I go from here i'm lost at this point?
Thanks for any help.
Old Feb 9, 2014 | 05:55 AM
JasonYota's Avatar
Check your AFM. If the ECU doesn't get a signal that air is flowing it will not start.
Old Feb 9, 2014 | 11:47 AM
webmailjoe's Avatar
Check the AFM and it checks out ok. So what is my next option?
Old Feb 9, 2014 | 11:56 AM
JasonYota's Avatar
How did you test it? Is it getting power? Try the igniter
Old Feb 9, 2014 | 12:26 PM
webmailjoe's Avatar
I checked the AFM with ohm meter and plugged back in and tested the voltage when blown through. I will check the igniter.
Old Feb 10, 2014 | 04:06 AM
wyoming9's Avatar
Red face
With all this cranking and not starting have you pulled the plugs and cleaned or replaced them.
You are running the correct double electrode plugs??
Have your wires on correct ?
None of your connectors have bent pins??
All connectors were cleaned with contact cleaner.
These things corrode you can`t see it with the naked eye they will drive you crazy.
The readings with a meter are always good as well it is just when plugged together it does not work.
Old Feb 10, 2014 | 01:47 PM
webmailjoe's Avatar
Yes I'm running the correct spark plugs. Wires are correct. No connectors have bent pins. The connections that i have taken apart have been cleaned with contact cleaner.
Crazychris1871
Jun 27, 2016 10:38 AM
Sandman
Jul 23, 2015 08:15 PM
aciorba23
Jun 29, 2015 04:18 PM
newzingo
Jun 24, 2015 01:50 PM
Corey
Jun 10, 2002 04:23 AM
