Upper ball joint removal
Old May 29, 2014 | 03:04 PM
j-man's Avatar
how do i get that darn thing out? Im putting a set of camburg's on, but have to get the stocker upper joint out first...
Old May 29, 2014 | 06:25 PM
BigWavePaul's Avatar
A cheap pitman arm puller from HF modified to accept a 1.75" opening will do it.
Old May 30, 2014 | 04:40 AM
Nelsonmd's Avatar
You can do it pretty easily with a harbor freight 3-jaw puller too, though mine has been modified to make it alot stronger. I did this with my harbor freight 3-jaw puller and it went like butter.
Old May 30, 2014 | 05:18 AM
Jomoka's Avatar
You could also free/rent a ball joint press from Autozone. It's a bit of a PITA, though. Those things really don't want to move.
Old May 30, 2014 | 06:34 AM
offset442's Avatar
used a combination of a screw type ball joint press and an air hammer for some extra mojo, works good, better yet find a buddy with a shop press, i used a 12 ton and they where still a hard press, you will need the ball joint adapters from the screw type press to use as receivers on the bottle jack press other wise you can damage stuff trying to use sockets and bearing bits.
Old Jun 1, 2014 | 12:57 PM
2Whlin's Avatar
I purchased a Harbor Freight Ball Joint Seperator and it was piece of cake. May take a couple of whacks with a heavy hammer, but it should just pop right out.
Old Jun 1, 2014 | 05:13 PM
Jomoka's Avatar
There's taking the shaft out of the upper arm, which is fairly easy.
Then there's pressing the base of the ball joint out of the steering knuckle/upright, which is a lot more difficult.
krimsonone
Sep 13, 2024 09:33 AM
Swim
9
Jan 4, 2016 10:47 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
