Old Mar 30, 2016, 03:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Transmission Guides
Print Wikipost
1997 tacoma 5 speed transmission problem
Old Aug 14, 2010 | 05:19 PM
XoDiViAoX's Avatar
hello i have a 1997 tacoma it has the 2.4L engine, and 5 speed manual transmission 133k. when I shift from 2 to 3 and give it the gas, especially up a hill it feels like the engine is skipping .. i was wondering if this is a sign of a transmission problem, or what the problem might be? it only does it in 3rd gear, no other gears ever do it.
thank you
Old Aug 14, 2010 | 08:39 PM
scuba's Avatar
Describe "feels like the engine is skipping." Maybe your experiencing the clutch slipping. Is it the original clutch?
Old Aug 14, 2010 | 08:55 PM
XoDiViAoX's Avatar
Thanks for the response - I'm not sure if it's the original clutch or not, and the skipping has just started I believe. It's not the vibration feeling that you get when you've got it in too low of a gear. It's like you're accelerating and you feel a serious bump or jerk, or kind of like the engine skips, then you keep going it might do it 1 or 2 more times I guess. It only does it in Third gear, and it does it more when you accelerate hard up a hill.
Old Aug 16, 2010 | 09:38 PM
the_supernerd's Avatar
I would start with a tune-up if it has not been done recently. Plugs, wires, etc. I had a '97 Tacoma with the 3.4 that would cut out under load. I replaced the plug wires and coil pack boots and it fixed it. I would then check the fuel system if a tune up does not fix it. You can borrow fuel pressure testers from Autozone. That does not sound like a transmission problem to me. A bad transmission is going to grind, whine, or make some kind of noise. A slipping clutch is noticably different than an engine miss.
Old Aug 16, 2010 | 10:00 PM
XoDiViAoX's Avatar
Today someone told me it was probably some trash in the fuel system or fuel injectors, I'll start by changing the plugs and wires and stuff, and hopefully that will fix it. Thanks for the info supernerd.
Old Aug 17, 2010 | 04:28 AM
gdutch's Avatar
Could this be high gear / low rpm ping like the 3.4 supercharged guys experience? What octane gas do you use?
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
