front axle shaft
Old Jul 24, 2010 | 06:15 AM
warpigg's Avatar
Exclamation front axle shaft
the other day i had a major trail break down and dislocated my front lower ball jointand it pulled the axle out and ripped the c.v. boot. so i bought a new boot and it was the wrong size. it turned out that the axle was aftermarket and was smaller some how. so im going to buy a new axle today for 52 dollers but need the core from the old one. what tools do i need to take the axle out from the knuckle, more specicifically the size of the big socket?
Old Jul 24, 2010 | 07:50 AM
BajaRunner's Avatar
The socket size is 36 or 37 mm.
Once you get the hub nut off, whack the end of the axle shaft with a rubber mallet real hard, and it should dislodge from the spindle.
On the diff side, use a large flat head screw driver or pry bar. Wedge it inbetween the axle shaft (its really called a half shaft), and the diff, and pry it off. It usually will pop off quite easily. You'll feel a pop too. Some diff fluid will also come out so put a drain pan underneath.
You'll then have to move the spindle out of the way. Either by removing the 4 bolts on the bottom that hold it to the lower ball joint, or removing the upper A-arm bolt, which is not as easy IMO. I usually take off the 4 bottom bolts, and when putting the bolts back in using blue lock tite.
Old Jul 24, 2010 | 08:45 AM
scuba's Avatar
35MM, 14MM, and a pry bar.
Did you search?
http://www.4x4wire.com/toyota/maintenance/cv_axle/
Old Jul 24, 2010 | 09:59 AM
warpigg's Avatar
i got the inside part that goes to the diff out because it got pulled out when the ball joint failed, i just have to take the outside part off and thats it thank you BajaRunner
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
