97 3.4 overheats
Old Jul 15, 2010 | 09:59 PM
feste's Avatar
Question 97 3.4 overheats
Hey Guys!
I am new to this site and have spent most of the day doing research on overheating problems and solutions. A LOT OF INFO! This place is awesome.
Anyway, I am looking to buy a 97 4wd 3.4 4runner. Problem is it overheats. The owners have replaced head gaskets(heads re surfaced), water pump, t-stat, timing belt, plugs and wires, radiator and had the cooling system pressure tested. I have not taken a look at it in person yet. I want to be prepared with a plan of attack and figure out this problem. Where and how do you experts think I should start to diagnose this problem and hopefully get a screaming deal and a clean 4 runner? Or should I just walk and keep looking?
All help and advice is greatly appreciated.
Old Jul 16, 2010 | 04:29 AM
gdutch's Avatar
Man that's bizarre. If they replaced all of that stuff I don't see how it could still be overheating. Maybe the radiator cap is stuck down? Lol.
Old Jul 16, 2010 | 05:18 AM
Innervision's Avatar
Sounds like they have already replaced everything cooling system related.
You did not mention hoses... so maybe the lower radiator hose is collapsing?
The coolant passages in the engine could be clogged.
Ask if they used the right temp thermostat? Check the radiator cap?
Or maybe a long shot but there could be exhaust issues (partially clogged Cat) causing heat to build up in the exhaust system and thus the engine????
Did they change the head gaskets due to overheating? Or did it start after the HG change. Maybe they put them on wrong and blocked the coolant passages on the head????
It could also be a faulty gage. need to check the real temp not just what the gage says.
Old Jul 16, 2010 | 05:24 AM
BigBallsMcFalls's Avatar
why does it overheat ? is it the indicator saying itis hot or does it
actually fill up the overflow tank
automatic transmission ? check ATF fluid for coolant
stay away from anything that overheats, very bad omen
Old Jul 16, 2010 | 09:45 AM
tunnelmotor99's Avatar
Is it actually running hot? A bad gauge or sender can give you false readings.
Old Jul 17, 2010 | 07:37 AM
feste's Avatar
Should I check the hose after it is up to temp?
Can the water jacket be so clogged that you need to take the engine apart to clear it, or will back flushing do the trick?
How can I check if the cat. is clogged? Smog test? Feel exhaust coming out of the tail pipe?
I have a infared thermometer, where is the best place to check "real" temp? Radiator hose @ t-stat?
Thanks!
Old Jul 17, 2010 | 11:34 AM
feste's Avatar
Is their a fool proof way of checking that the gauge or sender is reading correctly?
Old Jul 18, 2010 | 10:44 AM
there are 2 temp senders
one for the dashboard indicator
one for the computer to run engine management
use an OBD-II tool and get the temp reading from the ECU
Steven.m.paulk
Jun 7, 2020 10:45 AM
primordialbeast117
Dec 19, 2015 12:23 PM
White Stripe
Oct 6, 2015 10:47 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
noahstancik
Sep 10, 2015 10:47 AM
