engine running after cut off
Old Aug 21, 2010 | 04:59 AM
northfacer581's Avatar
4runner has been driving a tad funny recently. acceleration seems a little weak, and exhaust sounds not as smooth, almost more like a go kart or something. so i pick up a can of seafoam, (i use one every oil change, have been for about 3 years) thinking that might help. i run half the can, shut the engine off, and it keeps running for about five seconds.
any thoughts? it scared the crap outa me.
Old Aug 21, 2010 | 06:13 AM
team_gforce's Avatar
carbon deposits in the cylinders? if deposits get hot enough it could act as the ignition source casing the engine to "diesel" after you shut the key off
Old Aug 21, 2010 | 06:21 AM
Buck87's Avatar
x2 could be timing.
Old Aug 21, 2010 | 09:28 AM
ScottyC's Avatar
THIS /\
But its in the intake. Likely need to pull the intake and clean it out really well. Something is clogged. You are likely getting a lot of blow-by and the intake is full of sludge and crap.
IMO, Seafoam is not supposed to be used the way you are using it. Only use it every few oil changes and only for the last 100 miles before you change the oil. It breaks loose deposits, but then those deposits float around inside the motor as long as you run it. So, the oil needs to be drained out to get them out. My guess is that the seafoam has now caused the issue you are having. Things need to be cleaned out. Or your motor is going to be toast.
Old Aug 21, 2010 | 04:49 PM
rob17san's Avatar
When I used seafoam before, it fouled my spark plugs. Check that too.
Old Aug 21, 2010 | 06:58 PM
Buck87's Avatar
Are you due for a tune up?
sonic concepts
Aug 16, 2025 03:13 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
puffin04
Jul 10, 2015 09:17 PM
noahstancik
Jul 10, 2015 11:18 AM
