Replaced 2004 Tacoma 4 Cyl Water Pump
Old Aug 4, 2010 | 01:17 PM
Mike Murrell's Avatar
My 2004 4 cyl Tacoma started leaking coolant late last winter. At first it was a small leak - lost about 1 oz. every 150 miles, but as we got into early spring the loss picked up a bit.
A bit disappointed that a Toyota with just 60,000 miles on it had already developed a faulty water pump. Vehicle has the 100K pink coolant.
Followed the disassembly instructions found in an online Tacoma factory service manual. Pretty straight-forward as water pump change-outs go.
http://www.ncttora.com/fsm/2003/index.html
It was my introduction to metal water pump gaskets.
Wasn't sure if a sealer was needed or not.
Contacted Permatex at their WEB site. Was told to use Permatex Hylomar #85249.
5000 miles later things are holding up well.
Replaced original factory water pump with a dealer Toyota water pump. Approx $123.00 + tax. Came with a water pump gasket.
Old Aug 4, 2010 | 04:09 PM
Nevin's Avatar
You do the timing belt while you were there?
Old Aug 4, 2010 | 04:52 PM
2004 Toyota Tacoma - 2.4 litre is equipped with a timing chain; not a timing belt.
Modern day 22-RE
Old Aug 4, 2010 | 04:56 PM
Nevin's Avatar
Modern day 22-RE
oh yea duh
voiddweller
19
May 2, 2016 09:10 PM
B. Graves
Jul 3, 2015 04:10 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
infinityisfive
Jun 16, 2015 06:51 PM
