Love my 4runner, maintenance questions
Old Aug 6, 2010 | 10:18 AM
link434's Avatar
Smile Love my 4runner, maintenance questions
It's about that time, I'm at 173k miles, not really any problems yet but I thought i'd give her a breather.
So, I just added 1/3 can seafoam via PCV valve, waited an hour... Drove her around she coughed out some smoke but no real noticeable improvement. I was skeptical at first.
Added another 1/3 can waited 2 hours, this time she coughed out about the same smoke but MAN she ran so much smoother. My baby's back!
Added the last of the can, and I'm going to wait about 4 or 5 hours before the last run.
So next I plan on adding my other 2 cans to half a tank of gas, running her until around empty and refilling.
I also plan, on:
Cleaning the KN Air Filter
Oil Change (she's been on mobile one synthetic since I got her)
Replace Plugs + Wires (got some denso plugs and NGK wires)
Cleaning the throttle body if needed when I do the plugs
and finally
Clean MAFS (if necessary)
My question, is do I need to wait until I drain the tank with the seafoam in it before I replace plugs or do the Oil Change? Forgive me I'm not very mechanically inclined, it will be my first time doing regular maintenance besides an oil change
Thanks guys, also, is their any other easy maintenance I should add into my plan? Or actually, at around 170k what should I have the shop do for me?
Old Aug 6, 2010 | 12:21 PM
Deceptiwave's Avatar
Dont worry about the seafoam in the tank before/after the plugs. Either method is fine.
At 173K I would check the tranny fluid and change if needed, do the front/rear differentials and the transfer case.
Coolant swap would be a good idea as well.
Old Aug 6, 2010 | 02:03 PM
Nevin's Avatar
Whats Seafoam?
Old Aug 7, 2010 | 11:28 AM
J2F42C's Avatar
Originally Posted by Nevin
Whats Seafoam?
http://www.seafoamsales.com/
Used on a 2001 Tacoma:
http://www.youtube.com/watch?v=Mt6og8q9pk4
Old Aug 7, 2010 | 01:57 PM
link434's Avatar
will do, thanks
today I finished the plugs and wires, and cleaned the k&n filter... I'm going to drive it a bit before I clean the MAFS and the throttle body in case the oil from the air filter comes off a little.
Old Aug 9, 2010 | 02:01 PM
link434's Avatar
More progress.
Removed the throttle body to clean it out, and decided to go ahead and dremel the D lip off the gasket. Also drilled some holes in the airbox for extra flow.
She's running like a bauce.
I'm thinking about porting an polishing the TB, any thoughts on that? worth the time? Also, does the ISR mod require a tune?
Old Aug 9, 2010 | 03:43 PM
LifterCatcher's Avatar
Cap & rotor
Old Aug 9, 2010 | 04:33 PM
peapicker's Avatar
Originally Posted by LifterCatcher
Cap & rotor
I hope you are kidding!
Old Aug 10, 2010 | 05:16 PM
pregreentaco's Avatar
I used seafoam for many of my rides, but then I heard someone say that they are bad for your fuel injectors....?
I started using highest octane gas instead (91 in CA)
Old Aug 11, 2010 | 07:05 PM
link434's Avatar
Cleaned the MAFS today, still got the ISR mod up for debate.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
Cplmike
Jul 8, 2015 08:47 PM
colinmil
Jul 6, 2015 04:03 PM
