Front end Sagging(ARB bumper), what Springs to get
Old 07-29-2010, 08:37 PM
2000Tacoma's Avatar
I just bought a 2000 Tacoma 2.7 4x4 reg. cab, i really like the truck my only problem is the front end seems to sag a little, it has a ARB bumper which im sure is why its sagging. What can i do to help this problem, this is my daily driver and i want to handle good still. Im thinking of getting some OME springs but what kind should i get? Can i use those with factory shocks? Also would putting stock springs off a 3.4 tacoma help are the stiffer? thanks
Old 07-29-2010, 08:51 PM
scuba's Avatar
Well.. It doesn't sound like you want to lift it.. If so I'd recommend OME 882's,
You can go with some 881's and probably be back to stock height.
You shocks are probably worn too, so just buy some OME shocks while your doing the whole thing.
Old 07-30-2010, 08:35 PM
2000Tacoma's Avatar
could I use other brands of shocks, like less expensive ones?
Old 07-30-2010, 08:46 PM
scuba's Avatar
Could you? Sure.
Is it recommended? No.
The valving in all of the other shocks is not going to match the spring rate of the OME springs.
Do it once, do it right.
Old 07-31-2010, 07:36 AM
FogRunner's Avatar
I would go with the 883 over the 882s. The 883s give you almost as much lift as the 882s but they have a higher spring rate and won't sag like the 882s tend to.
FOG
Old 07-31-2010, 08:17 AM
scuba's Avatar
FOG
On a single cab trying to get back to stock height??
Old 08-03-2010, 09:15 PM
2000Tacoma's Avatar
has anyone had experience with the Daystar leveling kits?
Old 08-03-2010, 09:47 PM
scuba's Avatar
Don't use a spacer.
REPLACE THE SPRINGS AND SHOCKS!
Old 08-03-2010, 10:16 PM
JWaldz's Avatar
scuba is all over this one.. i was gonna chime in but looks like you got it all under control!
Old 08-04-2010, 06:49 PM
2000Tacoma's Avatar
Im probably going to go the OME spring and shock route, now which should i get 882 or 883s, also what is a good place to buy them?
Old 08-04-2010, 07:43 PM
aa1911's Avatar
check out NWOR's website, they have some shnazzy 'racing' suspension and a luxury ride suspension for front and rear; they do add about 2.75" up front but they claim they are 0-3" adjustable; I plan on buying the racing suspension for mine and trying them out as I don't want much if any lift, the guys I talked to at NWOR seemed to know a good deal about their stuff, worth a call. Might be too much for you but it will take care of any sag and improve handling quite a bit for sure.
yeah, NO spacers... and get new shocks!! bilsteins have a proven reputation; $300 bones for 4.
OME might be the route I go in the end though...
Old 08-04-2010, 07:44 PM
aa1911's Avatar
I'm surprised nobody has suggested you to crank your torsion bars yet hahaha...
Old 08-04-2010, 09:42 PM
scuba's Avatar
882's are going to be 2" over stock height with the ARB after settling.
Prepared to lift the rear too?
Buy from Gooverland or Wheelersoffroad
Old 08-05-2010, 12:48 PM
2000Tacoma's Avatar
Im not really wanting to lift the whole truck, just wanting it to sit level.
Old 08-05-2010, 01:18 PM
Ripcord_4Runner's Avatar
NOTE: 882 and 883 coils require matching OME 90004 front shocks
Taken from toyteclifts.com, OME dealer.
Coils: http://www.toyteclifts.com/index.php...mart&Itemid=72
Shocks: http://www.toyteclifts.com/index.php...mart&Itemid=72
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
nick9455649
09-11-2015 05:10 PM
Nickdigg
07-07-2015 06:04 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Front end Sagging(ARB bumper), what Springs to get
