front end shake
Old Jul 11, 2010 | 06:10 PM
billkmiami's Avatar
Question front end shake
My 1997 4 Runner has 157000 miles on it. Replaced all four tires with in the past year- Sumitomo All Terrain tires. My 2wd 4 Runner has developed a front end shake starting at about 63 mph. Can't be the tires already need a rebalance? I think the front end needs possibly new bushings? Has anyone experinced this with their truck and what did you do to repair this?
thanks
Old Jul 11, 2010 | 06:27 PM
waskillywabbit's Avatar
Classic tire out of balance.
Old Jul 11, 2010 | 09:41 PM
billkmiami's Avatar
puzzled why a tire would lose its balance? My wife drives this truck- basically it is a grocery getter- unless she hit a bad bump? any other thoughts?
thanks
Old Jul 12, 2010 | 04:37 AM
gdutch's Avatar
Yeah, that happened to me after I got new tires as well. The store probably didn't balance them correctly. There's many other threads about this subject, but the problem is that Toyota wheels have their weight centered around the lugs, NOT the hub like most other wheels. In order to balance them correctly, there is an adapter that attaches to the balancer that has five lugs on which to place the wheel, as opposed to the standard practice of mounting the wheel by its hub. If they don't use the adapter, your tires WILL be improperly balanced. I would suggest you go back and ask them to do it again, the adapter is called a "Haweka adapter," although I think some places just call it "fingers" due to its appearance. . . If they can't / won't do it, just take it to your stealership, they will certainly have the necessary equipment. Let us know your results.
Old Jul 12, 2010 | 05:07 AM
thanks
A tire can get out of balance if a butterfly farts on it. She could have hit a curb, hit a pothole, a wheel weight fell off, tire pressure is low, uneven wear, anything can change the weight and/or change the balance.
Get the tires balanced. It is not a do it once for eternity kind of deal. Tires have to be rebalanced sometimes.
Old Jul 12, 2010 | 09:22 AM
billkmiami's Avatar
ok will do- i will report back with my results! thanks
Old Jul 12, 2010 | 10:21 AM
scottishb's Avatar
Steering rack bushings? Loose skid plate? Tie rods?
Old Jul 12, 2010 | 10:38 AM
Fink's Avatar
Fink
Old Jul 12, 2010 | 08:54 PM
billkmiami's Avatar
ok thanks
Old Jul 12, 2010 | 09:00 PM
2DoorRunner's Avatar
^loose skid plate
Yeah i bet your wife hit a curb or something.
Or maybe a butterfly really did fart on it
Old Jul 12, 2010 | 10:26 PM
scottishb's Avatar
Originally Posted by 2DoorRunner
^loose skid plate
Yep, at highway speeds the plate can get shaking pretty good if the bolts are loose. The alignment gods forgot to tighten mine after they were done and it shook and vibrated like crazy. Sorta felt like a bad u-joint.
Old Jul 13, 2010 | 10:41 AM
hmm, i never would have thought something as small as the skidplate could do that.
You learn something new everyday
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Daneums
Aug 20, 2015 05:36 AM
v_man
Jul 23, 2015 04:01 PM
