Interchangeability of clock springs (spiral cables)
Old Aug 16, 2010 | 12:12 PM
JBurt's Avatar
So my clock spring broke and the first replacement one I got was also broke. I soldered the first one back together and it looks ok but I decided to just get another one because I couldn't think of a good way to insulate the soldered wires. The part number (under the bar code) on the origonal is UIA.N6N.2196 and the part number on one I found at a junk yard (same year and same options) is UWA.Y78.5626. I think it would work but before I drive the 2 hours to the junkyard I wanted to ask to see if someone smarter than I am could tell me if it would work. Thanks.
Old Aug 17, 2010 | 07:27 AM
JBurt's Avatar
Also, would driving the truck without the clockspring until I get the new one do anything weird, like mess with airbag sensors?
Old Aug 22, 2010 | 09:16 AM
martinfan30's Avatar
NEVER SOLDER AN SRS/Air bag CIRCUIT!!!!! You will change the resistance values in the squib that will affect operation. It may not deploy when you need it, and it may deploy inadvertantly if you make a mistake.
By driving without the clock spring, you will have a SRS/Air bag MIL lamp on, and you will have no SRS protection in event of a collision.
Another circuit you should never solder is an O2 or A/F sensor circuit. Again, it changes resistance in the circuit. It will not give the ECU correct exhaust gas calculations.
Old Aug 22, 2010 | 11:36 AM
JBurt's Avatar
Thanks. Glad I ordered another one. Hopefully I'll get time to put it in tomorrow morning.
Old Aug 22, 2010 | 12:23 PM
mt_goat's Avatar
I've done both of those installing URD fuel mods.
Old Aug 22, 2010 | 03:14 PM
It can be done with good solder and technique. I have occasionally seen an issue with this in O2 and knock sensor circuits.
80Truck
Oct 12, 2025 07:25 PM
Scatpac
May 25, 2017 06:47 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
terminator
Jul 27, 2015 07:13 PM
