A/C expansion valve
Old Jul 25, 2010 | 10:45 AM
craigoryjames's Avatar
A/C expansion valve
Hey everyone. I just replaced my expansion valve on my 96 4runner and have everything hooked back up with a vacuum pulled. I am a hvac guy, but since I did not replace the compressor I do not know how much oil I should add to the system. I have a 1oz. Do you think that would be enough? Thank you everyone for your information.
Old Jul 26, 2010 | 10:29 AM
tunnelmotor99's Avatar
If you didn't lose any oil you don't really need to add any, although adding some with dye would be a good idea. 1 oz should be fine added to the low side.
Old Jul 26, 2010 | 08:07 PM
FogRunner's Avatar
You don't need to add any oil. If you have access to a charging scale charge the system by weight. Even though its got a expansion valve its really finicky about the charge and very easy to end up with a couple OZ too many or too little when charging with gauge/eyeball method.
FOG
MO transplant
Apr 23, 2023 11:58 AM
Sarcazmo
Aug 15, 2015 08:22 PM
stock87yota
Jul 31, 2015 10:08 AM
jackiebrownia
Jul 20, 2015 09:02 AM
bryan34w
Jul 6, 2015 05:53 PM
