Sliding Ashtray
Old Jul 20, 2010 | 12:33 AM
ahtub's Avatar
Sliding Ashtray
anyone know a fix for this thing? it just keeps popping back out once i drive off anywhere....even when it's empty.
any input is appreciated. thanks in advance.
Old Jul 20, 2010 | 05:22 AM
gpcollen1's Avatar
How about just wedging a piece of paper or tooth pick in there to keep it tight??
Old Jul 20, 2010 | 02:44 PM
JWaldz's Avatar
I myself had this problem, mainly opened on the trails and when it was full of change. I took a small piece of velcro and put it on the back of that small lip and then on the opposite side. Kept it closed a lot better.
Old Jul 20, 2010 | 02:52 PM
Tofer's Avatar
Sponsor
Old Jul 20, 2010 | 03:20 PM
2DoorRunner's Avatar
I like that idea!^
Old Jul 20, 2010 | 09:31 PM
rjaudi's Avatar
I disassembled the tray and bent the spring to make the ashtray closer tighter. It defintely helped this out. A new ashtray is 70 bucks at the dealer.
Old Jul 21, 2010 | 06:18 AM
Kerby J's Avatar
try salvage yard a whole lot cheaper
Old Jul 21, 2010 | 09:14 AM
Jefe23's Avatar
What I ended up doing that worked is remove the two (2) screws that hold the metal frame in place. Once you remove the frame, just pinch the sides together a bit where the plastic slides are. This worked like a champ and with an ashtray full of change it stays put. It's an easy and free fix!
Old Jul 21, 2010 | 02:35 PM
sportrunner2001's Avatar
I took mine out and the metal frame to fit some iPod fm tuner in there. The wire was about five-six feet long. and that little light that lights it up looks cool at night. But then mine burnt out. I'm devising a way to fit the gps down there somehow...nevermind about that. Do you really need it is the question.
Old Jul 21, 2010 | 03:44 PM
Mtn Mike's Avatar
I took out my ashtray because I never used it. With it removed the green ashtray light actually looks kind of cool shinning down on the lower consol. Now I also have room to mount something down there but haven't decided what to put in the space.
Old Jul 23, 2010 | 12:04 AM
ahtub's Avatar
thanks for the replies guys. the tooth pick worked like a charm.
Old Jul 24, 2010 | 09:21 PM
dave_mcmillan's Avatar
This is why I joined this forum...making 200,438 miles a little more ejoyable.
Old Jul 25, 2010 | 07:36 AM
Big Bird's Avatar
I thought I was the only one with these "problems"; sliding ashtray, seatbelt hanging out the door, moonroof halfway safety switch, and fuel guage going down 1/4 in first three miles. It's all part of some Toyota engineer(s) plan.
Old Apr 6, 2014 | 03:52 AM
robmtguy's Avatar
Ashtray Parts
I am wondering does anyone know where to get those clips that make the ashtray spring up, I have looked all over my junkyards here to no avail, is there an aftermarket place I can buy them? It is the black metal parts. . .
Old Apr 7, 2014 | 01:09 PM
If I new where mine went I would send it to you haha
but check out tps.toyotaofdallas.com they might have it. it'll take some looking to find it but they have decent prices on OEM parts. I just ordered a new PCV valve and fuel filter from them. Or check with your local dealer
Old Aug 8, 2018 | 07:36 PM
11city's Avatar
Where did you put the toothpick to fix the ashtray?
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
JookUpVandetti
Sep 24, 2015 08:56 AM
mat
Sep 17, 2015 11:18 PM
TDonkey
Jul 26, 2015 10:14 AM
