99 seatbelt problem
Old Jul 8, 2010 | 12:44 PM
mmml4's Avatar
99 seatbelt problem
99 4runner SR5 v6
I was in a salvage yard the other day and found some front seatbelts to replace mine that are locked up (airbag deployment). I pulled on the belts to make sure thet were'nt locked up and they extended and retracted fine. So I told Fernando I wanted them and he removed them for me.
The problem is now that they were allowed to retract as far as they could they will only extend a tiny bit and then they catch and stop. Is there a trick to get them to extend?
Thanks
Old Jul 9, 2010 | 05:47 AM
BigBallsMcFalls's Avatar
a pendulum locks them. remove and rotate the assembly on xyz axis and it should
eventually unlock. then pull some out and bolt them back in
Old Jul 9, 2010 | 06:22 AM
mmml4's Avatar
Thanks for the input, I'll try that. I figured if I had to I could take my old ones apart and see how they work. Just seemed odd that after I got them home they would not extend.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Jonny246
Jul 24, 2015 12:37 PM
mluz013
Jul 24, 2015 12:31 PM
kyletbert
Jul 17, 2015 11:39 AM
