Aloha Bruddahs! MissFire P305
Old Aug 15, 2010 | 01:54 PM
TacoTime's Avatar
Talking Aloha Bruddahs! MissFire P305
Sup Guys, here on maui with one poor running Tacoma
V6 3.4 180k well maintained
2nd T belt @ 118k
Misfires started about two months ago, It actually started on cylinder 3, so I swapped coil packs from cylinder 3 with cylinder 5 and the misfire moved. I thought, great, that was easy, just a bad coil pack. However, now I'm getting misfires from cylinder 5 once again, and it's a brand new coil pack OEM.
The misfire has remained on cylinder 5, never returned to cylinder 3. for two months and around 600 miles.
Have replaced
plugs with nkgs, dual
plug wires OEM
replaced fuel injector (#5) OEM
Still stumped, anyone have any ideas.
I don't think it's the timing belt, what do you think? bad timing belt should give me multiple cylinder misfires
I'm thinking it's either fuel or spark
I have compression tester on order, got a meter on order, and fuel line pressure gauge.
Shootz, den anybody who uncovers my problem will get some fresh Lilkoi butter
Aloha
Old Aug 15, 2010 | 02:42 PM
vital22re's Avatar
totally a bro
have you tried moving the coil pack back to 3? I realize its a new oem pack but just for giggles move it. If it stays at 5, i'm thinking maybe valve adjustment? You've cleared the codes since you replaced those parts right?
Old Aug 16, 2010 | 03:59 PM
TacoTime's Avatar
thanks for the reply,
yeah, I thought maybe I screwed things up. I cleared the codes and swaped coilpacs again, still missfires on 5.
I'm waiting on a fuel pressure gauge, just I can rule it out.
Anyone know what I should expect if I open these valves up. should I go ahead and get some shimes? I do have gaskets and washer gromets
Old Aug 17, 2010 | 02:32 AM
vital22re's Avatar
totally a bro
See if you can get your hands on injector pulse testers. Basically tiny leds that light up when the injector fires. You'll be able to watch the pulses and see if they miss a blink. Have you done a compression test yet bro?
Old Aug 26, 2010 | 02:02 AM
TacoTime's Avatar
I'll check it out, the injector is new so I'm pretty sure that it's working
doing a compression test in the morning will update
Old Aug 26, 2010 | 04:01 AM
84foyota's Avatar
Sounds like a tight valve
I would lean towards a burnt or tight valve. Take the valve cover off and check the valve clearance with a set a feeler guage. If the clearence is too tight the valve will not fully seal properly (especially when warm) and will give you an intermitant miss.
You can also do both a dry and wet compression test (poor a little oil in the cylinder for the wet test). If the results are the same on both tests and the compression is low on the cylinder then its a leaky valve. Carbon on the valves from leaky valve stem seals often causes issues with valve clearance and can lead to a burnt valve or a valve that sinks into the seat slightly and looses clearance.
Old Aug 26, 2010 | 04:31 AM
eddieleephd's Avatar
x2 for checking injectors even just swap #5 with another and see if it moves and SEAFOAM!!!!!
Old Aug 26, 2010 | 12:15 PM
TacoTime's Avatar
thanks 84, looking up valve specs now
andrewtexas123
Sep 23, 2015 07:48 PM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
anndel
Sep 10, 2015 08:50 AM
PakShak
7
Feb 18, 2004 10:47 PM
