Adjustable Bilstein shock suggestions
Old Aug 4, 2010 | 04:06 AM
sl0annuggets's Avatar
Hey so I just installed my adjustable bilstein adjustables. And the coils have settled much lower than expected. Could I get some OME 881s or something to match with these if I leave it on the stock or 1.5 in setting??
Old Aug 4, 2010 | 04:48 AM
JWaldz's Avatar
A lot of people don't like the ride quality with those bilsteins. I personally have them and they ride is fine but they are a pain to mess with. Try putting them in the middle setting. If that doesn't help then yea you could get new coils and put them on the lowest setting. You might have a small rake.
Old Aug 4, 2010 | 04:52 AM
waskillywabbit's Avatar
Please use relevant titles for your threads in the future or they will probably be deleted per the posted sticky concerning thread titles at the top of each section.
Old Aug 4, 2010 | 05:24 AM
They are currently in the middle setting but the coils have just decided to pretty much die..
So should I get stock coils or 99's? or go OME and leave them in the middle? Because something definitely needs to be done.
Old Aug 4, 2010 | 07:27 AM
Mauzer's Avatar
Why aren't you using the tundra coils? (not flaming, just wondering)
Old Aug 4, 2010 | 08:35 AM
JWaldz's Avatar
Well like Mauzer said u could get some Tundra coils and probably fix the issue. I wouldn't put the setting up to high cus the ride would be very stiff and bouncy. You wanna stay at stock levels and keep the billies get the Tundra coils.
Old Aug 4, 2010 | 10:09 AM
That sounds like a good idea. Ill probably be able to find those easily or semi easily. I am guessing the 00-06 are the years Id be looking for right?
Old Aug 4, 2010 | 10:56 AM
Mauzer's Avatar
Correct, check your local JY, tundrasolutions, or here is an ebay listing (the seller always has tundra coils)
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
Old Sep 1, 2010 | 05:13 AM
How much does just the coil weigh??
Blamalam
Mar 12, 2022 07:34 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
SMOD
Jul 27, 2015 01:45 PM
Massmayhem247
Jul 18, 2015 05:46 AM
