Big Tranny Question ?
Old Apr 13, 2018 | 07:06 AM
XPY's Avatar
XPY
How easy is it, or is it even possible, to take two 3rd generation 4Runner, and change (switch) the transmission / clutch systems from an automatic to a manual from the two trucks ?
Second question: Manual V6 tranny / clutch system, into a Automatic V8 ?
Old Apr 13, 2018 | 10:33 AM
fierohink's Avatar
I'll try to break this into smaller parts of possible incompatibility, because there is a lot to this simple sounding question.
Bellhousing - > Since the engine isn't different for STD vs AUTO, they should bolt up. Provided you are using V6 to V6 or I4 to I4. I don't know for sure if V6 to I4 (or vice versa) has the same pattern.
Cross Member - > Again the frame is the same regardless of transmission, so as long as you maintain the cross-member with the matching trans, you should be okay.
ECU - > ECU part numbers are trans specific. You can try to use the A/T ECU with a M/T, but the information may not be compatible. You might be able to re-pin the harness to make it work, or you might need to swap ECUs as well.
Driveshaft -> These are usually trans-specific in length, so again as long as you had the corresponding DS you should be okay.
"Clutch system" - > Provided you are using similar motors ( 5VZ to 5VZ) then you would buy the appropriate flywheel, clutch kit, and slave to use in your newly installed M/T. if you are using a V6 trans on an I4 or vice versa, you may have to pick and choose between V6 parts and I4 parts or score the correct bellhousing so you have enough room underneath for all your parts. You'll also need to run hydraulics from the slave to the master, depending on your states inspection process you might be able to get braided stainless fabbed up, or bend your own hardline.
The pedal assembly will switch as a unit, there are threaded bosses for the clutch master cylinder already on the firewall, if you want it to be pretty you'll need a corresponding center console, and various odds and ends may or may not make the switch i.e. cruise control might not work.
Anything is possible with the right tools and deep enough pockets.
Old Apr 13, 2018 | 10:40 AM
XPY's Avatar
XPY
http://www.lcengineering.com/LCTechP...ARJANUARY.html
Old Apr 14, 2018 | 09:01 AM
wyoming9's Avatar
Red face
Best bet is to have the complete donor vehicle at hand to save hours of running for stupid little parts .
That we all forget Like the brake pedal.
Tomh4x4
Mar 2, 2015 11:13 AM
Cp_fish13
15
Jul 22, 2004 04:11 PM
White SR5
106
Feb 10, 2004 10:03 AM
motrhedx81
10
Oct 16, 2003 09:13 AM
