Rubbing sound from front. Not tires
Been roaming around this site for a while, but this is my first post. Need some help and thinking this is he place to go! Been searchinga round this site for a while and couldn’t find anything.
Recently, I noticed when I’m at low speeds(ie parking, backing up) and have the steering wheel turned half-way or more, I’m getting a rubbing sound from the front end of the truck. Originally thought it was a bad cv axle, but those checked out. Haven’t checked the wheel bearings yet, but it happens no matter which way I turn the wheel. The noise is more noticeable in reverse, but I can faintly hear it in drive, too.
I should mention i ion I bought this truck a couple months ago and have replaced the pads, rotors, shocks and struts. It’s a 1999 sr5 sport with 157k miles. Any help is appreciated! Thanks
NorthCalifT4R,
I suggest having an assistant turn the steering wheel both directions while tires are on the ground and you observe whether wheel moves with respect to backing plate. Hoping you get this figured out quickly.
Bighead
Sep 26, 2014 03:26 PM
lastname_firstname
Jun 10, 2012 05:32 PM
