Sponsored by: CARiD
Front tires rubbing
Old Feb 21, 2008 | 07:31 PM
Grimone's Avatar
Front tires rubbing
Hey
Ive lifted my 92 toyota pickup with a 1.5 bodylift
I have 33 x12.5 tires to put on,
currently I have a pair of 33's on that are a width smaller and they still rub,
I know when i put those 12.5's on there gonna rub like crazy.
Can anyone suggest if I should get wheel spacers, or special rims.
If so what kind of rims, what kind of wheel spacers?
Thanks Id really appreciate any help
Old Feb 21, 2008 | 07:42 PM
JohnnyRanger54's Avatar
Just visit Toyteclifts.com... Great people, great product, extreme value...
Old Feb 21, 2008 | 07:48 PM
colsoncj's Avatar
I believe a 3.75 offset may help you a little, but you're goina rub... take a hammer to your pinchweld at the back of the wheel well, that should help a little, and reduce tire punction or damage possibilities.
Old Feb 21, 2008 | 07:56 PM
elripster's Avatar
http://www.ultimateyota.com/index.ph...6&topic=3876.0
Here are some pics and descriptions of what I did.
The more the offset (less backspacing) the more you will rub.
If you mod your fender wells like I did you might be Ok since yo already have a body lift. I plan to install a 1" to help with the last little bit of clearance.
Frank
Old Feb 21, 2008 | 08:05 PM
colsoncj's Avatar
good call frank... i forgot the 3.75 is only necessary for spindle lifts where ball joint clearance becomes an issue if you run a wider rim...
Old Feb 22, 2008 | 08:58 AM
mojo4x420's Avatar
Hey Frank, what offset rims are you running?
cheers,
rob.
Frank
Old Feb 22, 2008 | 07:01 PM
bigarms23's Avatar
buy a set of wheel spacers
Old Feb 22, 2008 | 07:51 PM
elripster's Avatar
I'm running stock which I believe is a 4.5" back spaced 7" wide rim.
Frank
Old Feb 22, 2008 | 11:00 PM
4Crawler's Avatar
Stock IFS wheels are around 4.75" backspacing, at least that is what I measured on this steel rim:
I assume the alloys are about the same.
Old Feb 22, 2008 | 11:10 PM
stormin94's Avatar
The OP failed to mention if he was running stock, or aftermarket wheels.
Old Mar 1, 2008 | 04:38 PM
n16ht5's Avatar
put in some bump stop spacers if all else fails
Old Mar 1, 2008 | 04:59 PM
camo31_10.50's Avatar
just run some wheel spacers....it'll help out everything...but dont go over about 1.5" MAYBE 2" if you dont wheel hard...cuz it F#$%# with the bearings...
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
PlayAwhile
Jul 20, 2015 11:36 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
