91 rubbing sound?
Old Feb 12, 2004 | 08:01 AM
newjerseyredneck's Avatar
91 rubbing sound?
I just started getting rubbing soud once in a while on my 91 164,000 mi. at speeds of 20 mpr or more when I hit a bump it goes away. Does anyone know what that could be?
Old Feb 12, 2004 | 11:20 AM
85runner's Avatar
You need to be more specific
Old Feb 12, 2004 | 11:47 AM
rubbing
Hmm.. YOu know like somethings rubbing....like....well a rubbing... it starts when ya hit a small bump and then it stops when ya hit the next one. Rite under the truck.. I cant figure what it could be. Started this winter.
Old Feb 12, 2004 | 12:02 PM
Fink's Avatar
Rubbing as tire hitting fender or rubbing as in metal against medal or...just what kind of rubbing it sounds like.
I have minor rubbing from my tires on my fender lining when at full turn going in reverse...that sounds like a tire rub...what kind are you experiencing?
Fink
Old Feb 12, 2004 | 12:37 PM
85runner's Avatar
Maybe its rattling. Something gets knocked loose on one bump and the next bump knocks it back into place. Check CAT heat shield.
Old Feb 12, 2004 | 12:49 PM
Memphis4X4's Avatar
Is it directly under the truck like it is a drive shaft? Or is it at one of the corners like it is a wheel? Does it only do it when hitting a bump or does it do it when it cold but not hot outside?
Old Feb 12, 2004 | 04:46 PM
Back again ...
The sound is a wailing/metal sounding noise - sounds like the emergency brake is sticking? The brakes don't seem affected, but the noise is extremely loud and harsh - sounds like Whoomwhoomwhoom - loud and low pitched. Started when we got lots of snow and daily freezing temps.
Old Feb 12, 2004 | 04:50 PM
lunatic14r's Avatar
check your rear drums you might have a lot of dust with water in it frezzing at night (it has been cold here has it been) and causing the drums to stick also check the exhauste see if it rubbing on anything
Old Feb 12, 2004 | 06:18 PM
Brendan's Avatar
If you've got a 22re, I'm going to go out on a limb and say to have a look at your timing chain. Mine would only make a noise around 2500 rpm.
Old Feb 13, 2004 | 08:09 AM
Memphis4X4's Avatar
Re: Back again ...
I know exactly what it is. There is a bushing inside your front hub that is made of brass and it is wearing out. Check out the last post on this thread
Mine does it and if I put it in 4WD, the howling stops because the driveline takes up any slack in the bushing.
David
Old Feb 13, 2004 | 12:35 PM
Doc279's Avatar
I had a drivers side CV joint boot that was cracked and the noise that you describe is exactly how mine sounded.
I replaced the whole shaft with both boots and have not heard the noise again. I would get a vibration when the truck was cold and the rubbing sound would come and go if I hit a bump.
Sometimes it would start and I would look for a rough place to hit just to stop the noise ! I'll bet you have the same problem.
Oh - I have a 1990 4 runner V-6 engine 208,000 miles and going strong !
Old Feb 13, 2004 | 02:05 PM
cv joint boot?
That sounds exactly like it. But Im not sure what cv joint boot is. How can I check it? By taking the front tire off? bryan
Old Feb 14, 2004 | 04:40 AM
CTB's Avatar
CTB
Just get underneath the front of your truck. Look to see where the front differential is, and then look to either side of it. You will see a shaft coming out either side that will have 2 rubber boots on it (2 per shaft). Those boots cover up and protect your CV joints. Inspect these rubber boots to see if they are ripped/torn/leaking grease.
Old Dec 30, 2012 | 06:50 PM
Millhouse's Avatar
I have the exact same noise and was getting frustrated trying to figure out how to describe it. I will check the CV boots and am pulling the front wheel off tomorrow. As a side note, do I have to take the whole manual locking hub cover apart to get the tire off? I was looking in the Haynes manual and saw how many pieces there was - a little bit intimidating for the novice. I will also check for a brass bushing. Are these bushings pretty readily available? Thanks (86 4runner)
Old Dec 30, 2012 | 07:11 PM
StewsRunner's Avatar
My front end squawked occasionally. I had a torn CV boot and it went away when I replaced the CVs. Another thing, I live in the snow and cold as well and my suspension gets noisy when I have snow packed in the IFS or wheel wells. My theory about mine is that everything freezes and then creaks and cracks when you hit it ie. crack in the road.
Old Jan 2, 2013 | 10:04 AM
Millhouse's Avatar
Fixed
So, I took off the fron wheel and started to remove the manual locking hub and then put it back together and now the noise is gone. Not sure what I did to fix it or how long it will last, but the strange noise has stopped. I did tighten a large thin nut a little tighter than it had been before; maybe when I reassembled the hub I did it correctly? Either way, thanks for the feedback.
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
matt1833
Sep 16, 2015 07:11 AM
langry345
Sep 14, 2015 03:36 PM
