tach mod 3.4 swap
Old Jun 16, 2018 | 08:33 AM
KeepKool's Avatar
tach mod 3.4 swap
Wrong year forum I know but this site with this pop up makes it difficult .... anyways
89 4runner 3.0 swapped to 3.4
Upgrading to SR5 instrument cluster and all works accept the tack now
Cluster came from a 86 or 87 but has the 6 at top of gauge leading me to believe it is out of a 3.0 truck . Just confused about where to add a resistor if that is what is needed ? And where to solder it in ?
Any help would be much appreciated , thanks
Old Jun 16, 2018 | 12:26 PM
wyoming9's Avatar
Red face
Check out the 3.4 swap threads lots of great info.
Possible the tach on your new cluster is broken or the trace broke loose.
The resistor is only if your cluster was from the 22r series. The tach works but not how it should
3.0 and 3.4 are just plug and play
Just what year ECM are you using your gauge might not be seeing the signal
When you wired the 4th plug you might have a bad connection .
Old Jun 30, 2018 | 06:01 PM
KeepKool's Avatar
Thanks for the response wyoming9 , I'm.thinking it might be a bad tach indeed although I can bump the gauge while out of the rig with a 1.5 volt battery and get a response . I have a good signal to and thru the harness plug into the cluster and was thinking it should work just fine but still playing with it . The one unknown at this point that might make a difference is what value and type of signal I would be getting from the 3.4 ecu as opposed to the original set up . Trying a potentiometer addition to see if adjusting the resistance value will do the trick as suggested elsewhere . I'll keep posting my results and hopefully find the solution .
dntsdad
3.4 Swaps
59
Oct 15, 2021 04:17 AM
defrag4
3.4 Swaps
Apr 26, 2017 08:53 AM
arroyobass
Apr 8, 2017 10:17 AM
mruuuk357
Mar 27, 2017 04:08 PM
egesledder
All Other Toyota Swaps
120
Feb 22, 2017 06:14 AM
