power loss
Old May 22, 2018 | 01:38 AM
Chevy's Avatar
power loss
994r 3.4 power loss under hard acceleration. by power loss I mean car slows . I have replaced plugs wires fuel pump and filter ,timing is fine at idle but when accelerating signal is lost. cleaned mafs replaced fuel pressure regulator
Old May 28, 2018 | 07:03 AM
fierohink's Avatar
When you say signal is lost, what signal are you losing? Crank position? Spark?
Under WOT conditions it should go closed loop and use reference data from the ECU. Anything less than WOT and it will use all the sensor data, TPS, MAF, O2, etc.
Do you have any CEL?
Old Jun 2, 2018 | 08:31 AM
Chevy's Avatar
99 4runner power loss
signal loss from tach that would be spark. the light from the tach is not visible. plus when it is hooked to the computer there are no codes during any position of the throttle.
Old Jun 16, 2018 | 06:48 PM
Soumipukuu's Avatar
Try a new air filter just for kicks, that's all I got
Old Jul 10, 2018 | 09:38 PM
theriddler33's Avatar
This is something to consider:
I've got a feeling mine may need a new crank gear so i'll plan on replacing it when the timing belt is done...let us know if you find the issue
Good luck!
Killdeer
Apr 29, 2017 05:49 AM
erock13
Mar 30, 2017 12:23 PM
Shagool22
Mar 26, 2017 12:44 PM
Rock Slide
58
May 27, 2008 08:41 AM
