Excessive positive camber
My son owns a 1997 4runner sr5 4x4. Just replaced the rack and pinion unit and now have excessive po active camber. Also driver side outer tie rod is threaded I'll the way in while passenger side is at least 20 threads. I measured everything before, and now it's all off. Half inch wider and thread counts l to r are way off...
need help
need help
It sounds like the old rack wasn’t at center when you spun off the TREs or the new rack wasn’t at center when you spun them on. That would account for mix matched thread count. Although TRE adjust your toe measurement.
Camber is adjusted through the cam bolt in the control arms. Did you change those?
also you should ask the mods to move this to the tech section not the build up area.
