2001 tacoma v6 2wd automatic transmission question
Hey fellas sorry if this is not the correct section, i have recently aquire a 2001 tacoma crew cab TRD v6 2wd with a bad transmission. I know a transmission from a 96-02 4runner will work physically but is there a specific year I need to look out for because I know electronically some things may be different in newer years on the 4runners.. which year is compatible with my 01 tacoma.. thanks in advance fellas
You might want to look through this listing and ask at least several different vendors https://www.ebay.com/b/Complete-Auto...154?rmvSB=true
I'm pretty sure there is no difference throughout 2WD transmissions connections and mounts on the 5vz-fe, but there is different gear ratios, you would be best to match it with the sticker on the door to be sure the gear ratio gives you the best milage and performance.
tunacan
31
07-09-2020 11:38 AM
4RUNR_FAN
22
03-13-2017 11:37 AM
jacobtodd123
02-25-2015 07:53 PM
Jrheingans
02-12-2015 03:36 AM
ger9147
Engine Swaps
01-08-2012 04:04 PM
