truck pulling to the right
Old May 27, 2018 | 11:19 PM
billkmiami's Avatar
Installed two new tires today- front end aligned- my truck was pulling to the right- still pulling to the right- everything seems tight- I installed new struts last year- ball joints seem ok as well as the tie rod ends- my steering rack is leaking though on the right side- can this cause the truck to pull to the right?? thanks!!
Old May 28, 2018 | 06:35 AM
fierohink's Avatar
Is it consistently pulling to the right or is it intermittent? If it’s consistent, I’d say you got a bad alignment. If it’s intermittent, then look for worn parts. It could be your steering rack, if it’s leaking there is wear, and where there’s wear there’s movement.
Your rack may need adjusted, there are threads on here for adjusting the steering rack guide bushing.
It could also be a bad control a bushing.
Or or possibly the steering rack mounts themselves. If you can get the truck up on a lift or stands, a little poking and pulling with a pry bar should make it evident.
Old May 28, 2018 | 09:47 AM
akwheeler's Avatar
WHAT IS YOUR TRUCK?
please post the printout from your alignment. the numbers tell a story.
Please define "pulling to the right" is it drifting or if you let go of the wheel does it veer toward the ditch? Is this ALL the time or does it seem to be only on certain roads?
the leaking won't cause a pull, but like fiero mentioned it could indicate wear. and if you replace your rack you need to redo the alignment.
Old May 28, 2018 | 10:30 AM
billkmiami's Avatar
sorry- forgot the details- truck is a 2000 TACO- if you let go of the steering wheel, the truck pulls immediately to the right- it will completely change lanes in about three seconds- consistently- always happen when you let go of the steering wheel...thanks!
Old May 28, 2018 | 11:24 AM
akwheeler's Avatar
Originally Posted by akwheeler
WHAT IS YOUR TRUCK?
post the alignment numbers please, I speak the language. Camber, caster, thrust angle etc.
Old May 28, 2018 | 04:59 PM
billkmiami's Avatar
see attached- thanks!
File Type: pdf
Old May 28, 2018 | 05:02 PM
billkmiami's Avatar
see a better copy
File Type: pdf
Old May 28, 2018 | 05:34 PM
akwheeler's Avatar
Where the heck did you go for an alignment? You got ripped off if they didn't give you a full printout, crayons don't count.
Old May 28, 2018 | 06:30 PM
billkmiami's Avatar
I know- it was tire kingdom- big tire chain down here in Florida- are you able to make anything out that tells you what you need to know?
Old May 28, 2018 | 07:04 PM
akwheeler's Avatar
the specified ranges are there, but not the actual readings, and I wouldn't believe hand written numbers anyway.
the good news is I figured out your problem, you need an alignment.
jessicaj
Aug 1, 2014 03:15 PM
Goldendale
Feb 2, 2011 04:01 PM
redvette
Sep 22, 2007 04:46 PM
joesrunner
Feb 7, 2007 07:23 AM
