Pre 84 Trucks 1st gen pickups
Pulling to the right
Old Sep 21, 2007 | 08:40 PM
redvette's Avatar
Why would it do that when I apply the brakes? Causes? fixs? 1981 4wd sr5 Thanks
Old Sep 21, 2007 | 09:21 PM
Kaleb's Avatar
Could be the road, could be the air in your tires, could be worn brake pads, could be air in your brake lines, it could be a number of things.
alexe's Avatar
left caliper could be seized.
Old Sep 21, 2007 | 10:07 PM
89macrunner's Avatar
i would put my money on the left caliper being frozen.
pull the pads and check the caliper out. If its bad i would go buy new loaded calipers from your local auto store. They might be pricey but they usualy have decent (bendix) pads and have a lifetime warranty. (I have taken advantage of mine already)
Old Sep 21, 2007 | 10:21 PM
Godzilla's Avatar
yup check the pistons in the calipers
Old Sep 21, 2007 | 10:41 PM
4banginRunner's Avatar
i'd check the air pressure in the tires along with the cailpers being frozen
Old Sep 22, 2007 | 02:20 PM
Barbarossa's Avatar
Good advice. Don't automatically assume caliper. Start cheap and easy then work your way up.
Old Sep 22, 2007 | 02:23 PM
alexe's Avatar
its fairly easy to check if a caliper is seized. its also the most likely culprit.
Old Sep 22, 2007 | 02:26 PM
CJM's Avatar
CJM
Tire pressure first, but its most likely a seized piston in your caliper. I would replace both with a loaded set from a parts store.
Old Sep 22, 2007 | 03:22 PM
denro's Avatar
My truck pulled to the right once, i rotated my tires..that was a easy fix...good luck with yours.
Old Sep 22, 2007 | 03:37 PM
keithguts's Avatar
Could also be the belts in the tire shifted out of wack. rotate the tires and see if it pulls tho the other side.
Old Sep 22, 2007 | 04:46 PM
toy283's Avatar
Another possibility: is the torque rod in place? This is the solid bar that runs from the tower on the front axle to the frame, right next to the draglink. If a previous owner (or yourself) removed it, axle wrap under braking will cause the truck to pull right.
Blamalam
Mar 12, 2022 07:34 AM
raptor510
Aug 19, 2015 02:15 PM
Feadship
Aug 1, 2015 12:18 AM
yourrealdad
Jul 21, 2015 11:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
