Pre 84 Trucks 1st gen pickups
81 yota pulling to right bad
Old Jan 30, 2011 | 11:34 PM
Goldendale's Avatar
My 81 4x4 is pulling to the right bad. At 25 if I take my hand off the wheel in less than a truck and a half legnth it will be in the ditch. Also at 50 to 55 is has a bad shake in the steering wheel. I have tried 2 sets of tires 2 sets of wheels and it drives the same. It is all stock with 235/75/15 tires. It was my moms truck before I got it so it hasn't been wheeld at all. I think it might be the wheel bearings any suggestions? Thanks
Old Jan 31, 2011 | 05:55 AM
dropzone's Avatar
Fossilized
Check the wheel bearings(you are probably in need of some maintenance anyway)
Spring bushings, tie rods, tie rod ends
Old Feb 1, 2011 | 07:33 PM
81 4X4's Avatar
Mine did the same thing. Front axle had moved. The hole in the center of the spring pad was oblonged, and let the axle move.
Old Feb 2, 2011 | 04:01 PM
slacker's Avatar
worn inner knuckle bearings , or even a sticking caliper will cause this as well ..
you really need to get in there and have a look !!
the1998sr5
15
Jul 14, 2020 08:35 PM
young buck
18
Aug 27, 2018 02:40 PM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
