PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. newbie with a ?
  2. Chakira Heddman headers??? anygood
  3. Long Travel kit for IFS a good idea???
  4. Getting in over my head with my axle.
  5. 1988 22re 4 runner
  6. ? weber 38 how bad is the mileage?
  7. parts sources for used parts/bumpers etc
  8. Toyota 22R
  9. 90 4Runner frame rust removal tips
  10. Upgrading to 4.88 Gears Cost?
  11. question about my 1994 4runner
  12. Regearing, suspension lift, TRD SC, tires.... In what order?
  13. Check engine light is on
  14. At how many miles did you Rebuild your Engine?
  15. toyota trekker interior pics needed
  16. rough country 4"lift kit
  17. Opinions on best headgasket seal kit to buy
  18. fuel guage going crazy!
  19. Did I BLOW MY ENGINE?? PLEASE HELP
  20. Newbie needs shocks
  21. dual t-cases
  22. Fenders 2wd vs 4wd
  23. turn my truck off and it just wont die
  24. 5100s and OME 885s
  25. Bleeding Brakes Issue!!
  26. tires for 94 22re
  27. '88 22RE Exhaust Questions
  28. Rear spring sag of 95 4runner
  29. Detroit Tru-Trac: Looking for advice
  30. 2x4 into 4x4 Questions
  31. new tires soon
  32. removing a siliconed connector.
  33. I bought another 87
  34. Anybody else have a hilux 2.8 diesel ??
  35. Need suggestions for chain replacement????
  36. New to forums/ headers to stock exhaust?
  37. 2002 Tacoma Auto, Violent 4wd disengage...
  38. 22r to 305 swap
  39. wheel studs fit loose invented rotors?
  40. Gas Mileage and Other
  41. 3.slow has gotta go
  42. Tire Size
  43. Planning on using my 97 4Runner to tow a Casita RV
  44. Denso Plug Wires PN# 671-4003 Any good?
  45. More Power
  46. only highbeams??
  47. 20r HeadGasket Replace, Help
  48. rebuild or swap?
  49. standard or xtra cab?
  50. Truck got a balck eye yesterday :(
  51. Inter-generation Body Panel Interchangeability!?!
  52. Key ignition problem
  53. 4Runner wont start after I replaced water pump, how do i get t running?
  54. Timing chain woes
  55. 4x4 shifter layout
  56. New Guy with bellhousing ID questions
  57. Replacing head gaskets on my 1992 Toyota Pickup DLX Ex-cab.
  58. Head Gasket Leak?
  59. Trailering
  60. Recommendation on a 3” suspension lift
  61. Non 3 link coil spring SAS
  62. Riding the clutch off road
  63. 2WD to 4WD conversion
  64. Cluncking noises when I turn
  65. Rear Main Seal, replace or not replace? Brand?
  66. Cone washers!!!
  67. Photoshop is harder than brain surgery
  68. Best tire for stock yota 4wd
  69. Replacement Shocks for 99 Limited 4x4 Stock Height
  70. opinions on lc's cold air intake
  71. Can anyone help on the mods on this t100
  72. Factory 4.88's
  73. start and electrical problems
  74. 22RE crate motor?
  75. 88 4runner locker
  76. 1981 toyota 4x4 help
  77. Sound deadener
  78. pump pully help.
  79. How slow should a 3.4L auto 4Runner be?
  80. ISR mod on a 98 T100 3.4
  81. possibly my 4runner got water in cold air intake and under distributor cap
  82. fuel system problems
  83. Looking for a front bumper
  84. gear oil in 88PU 4x4
  85. 4runner custom mods
  86. Little rust on the bed. POR15 no welding.
  87. 3vze bogging down and sluggish before 2500rpm
  88. Best shocks for standard suspension on an 87' 4wd Toyota pick-up?
  89. 4.7 tacoma
  90. spool or lockright???? cheap
  91. Softening ride w/ coilover conversion
  92. clunking noise after rear shoe install
  93. new rims
  94. spare tire carrier on 1st gen 4runner rear bumper?
  95. Stock body bolts
  96. Quick question on brake line nuts.
  97. do you have to remove head to change valve springs
  98. 1985 toyota reg cab first truck
  99. Will e-locker axle fit In my Tacoma?
  100. Wired carburetor
  101. 4runner running funny.
  102. 8" rear e-locker gears question
  103. coolant sensor and sender wiring locations.
  104. 88 22RE overheating
  105. Largest tires to fit on a 2wd PU?
  106. Just bought 99 Tacoma, questions
  107. Battery no start.
  108. 1st Gen Front/Rear Springs-are dodge spring compatible?
  109. Driveshaft Center Support Bearing.......
  110. Domed Pistons ver. Flat Top Pistons
  111. Compatible 22r Cyclider Heads
  112. 98 'Runner Lift Questions. (I've done my homework but I still have questions)
  113. dagnostic scanners
  114. 93 pick up sas
  115. Sounds like valve rattle at higher speeds
  116. Duralast crappy u-joint question
  117. Inquiry on 98 4runner and Tacoma/Tundra compatible brake components
  118. Oil pressure light issue
  119. Cost for transfer case and rear diff
  120. Newbie Mistake, Gear Reinstall.
  121. exaust question on 3.0 auto
  122. 98 4runner maintenance
  123. Replacing Fuel Pump on 91 Pickup 22re
  124. ignition switch removal - 90 truck
  125. Accelerates hard up hill is this normal?
  126. I broke a wheel stud for the first time
  127. Oh please not the head...
  128. need help 22re
  129. are my rear springs stock? what spacers to get?
  130. First time re-gearing question
  131. Starting problem 88 4 runner
  132. Truck starts when it wants to help 20r 77 2wd
  133. 4cyl 8" Detroit LocKer in 3rd Gen 4Runner?
  134. gearing question
  135. transfercase removal and front diff locked
  136. Need info on v6/turbo diffs/gears
  137. What is the operating/overheat water temp for an 02 V6 Tacoma?
  138. This is what it takes to get a FRAM oil filter off
  139. Questions, 1983 newbie
  140. need help in Las Cruces NM!
  141. pcv valve parts question
  142. 1988 toyota pickup lift
  143. 2002 4runner. Brand new bulbs. Tail lights wont turn on
  144. Question about the front axles on 95 4wd
  145. It lives!!!
  146. 00 4runner sas (trail-gear)
  147. 1984 Toyota 4x4 Newbie
  148. 91 Toyota Fuel problems when cold
  149. Hi-Lift Jack
  150. Newbie here looking for info on 4x2 pickup 3.0 headers
  151. Is it bad to leave ECT on all the time?
  152. Chevy V6 Swap
  153. 22re overheating Abnormally
  154. Front end vibration
  155. axle rebuild
  156. 1985 4runner questions?
  157. Body off frame help
  158. Gear Ratio Links Needed
  159. manually turning off e-locker
  160. 1991 Toyota Pickup
  161. over lifted issues
  162. Third Member Question
  163. 22R Weber WK746 32/36 DGEV-IC replacing stock carb
  164. 86 Toyota Coil Help
  165. Have to do slave w/ clutch master?
  166. fuel octane?
  167. Suggestions for poor running 22re
  168. Daily driving with dual transfer cases?
  169. lower radiator and lowerhose cold
  170. carb ? and blocks...
  171. What Shock/Strut to get??
  172. Limited Slip or Rear/Front Lockers?
  173. lower tcase gears or in my axle
  174. spool locker
  175. whats a good combination of body and suspension lift?
  176. 3.4 swap help
  177. 95 4Runner 3VZ RH cylinders not firing
  178. 84 knocks
  179. fuel pump tube
  180. Question on lift points
  181. starter recommendation anyone??
  182. 98 4runner lift help
  183. 94 pickup 22re suddenly no lights clock radio starter it is dead why? what do i do?
  184. E-locker on a 2001 4 Runner?
  185. Is it me or are truck beds weak??
  186. Truck wont start
  187. Cigarette lighter diagram??
  188. another newbie with issues
  189. Lifting my T100
  190. ECM code 42(speed sensor) '90 pickup 3vze
  191. 92 Landcruiser
  192. Can anyone identify this connector?
  193. Bumper and other parts
  194. 1986 22R carb. trouble
  195. CEL on '04 Tacoma - help!
  196. just bought an 86!
  197. ARB or Warn?
  198. Questions about locker install???Please read !!!
  199. Vibration when 4WD id disengaged...
  200. Gap between engine and transmission
  201. gearing? and lift questions
  202. any 4 cylinder parts fit 3.?
  203. Electrical help?
  204. 92 Pickup differential and rear axle housing questions
  205. The 3VZE Engine.
  206. no atf temp sensor
  207. Help yota newbie!
  208. CanBack top question
  209. 1987 DD Build help
  210. '92 22RE 120K miles, what to replace?
  211. 91 Pickup auto tranny problem?
  212. installing wondering
  213. No More TRD Camshafts for Sale?
  214. can't find the right engine coolant temp sensor
  215. Taillight compatibility
  216. ICE like air conditioning wanted!
  217. Metal Dashboard...
  218. weber carb help
  219. Stock 85 toyota tire upgrade?
  220. Broken wiper rod, how do I replace?
  221. 22r carb throttle linkage
  222. Timing Belt Alignment
  223. wheel felll off and lug holes on aluminum rims are elongated
  224. 1990 22re 2wd transmission mount?
  225. When to replace shocks?
  226. Speedo and Odometer dont work, Any suggestions?
  227. 97 transfer case out of a 4 runner and a 99 transfer case out of a tacoma
  228. manual hub conversions?
  229. compatible parts for my 86 22r
  230. 22re rebuild problem
  231. Removal of rear bench style seat from 94 extended cab and install in 86 Xtra cab
  232. 22re knocking noise on new rebuild
  233. Generic 3.4 engine questions?
  234. How to post photos on this forum (and most others) - how-to-guide
  235. 4" body lift on auto 95 4runner???
  236. Sensor Plud Identification Help
  237. IFS 4" lift
  238. gnarley vacuum leak
  239. how to ground a high-output alternator?
  240. Newbie. Swapping 22r engines, one auto and one manual.
  241. Axle newb: swap Taco axle into an '82 truck
  242. Whats going on with my spark plugs?
  243. W56 A-W56C tailhousing swap?
  244. where is my o2 sensor wire in a 86 4runner
  245. Leaf Springs Recommendations for SAS
  246. 22r Engine Mount Question
  247. Newbie Help - installing Leaf Springs
  248. Koyo radiators
  249. 5.71's or 5.29's with 39.5 iroks
  250. 3vze starts, wont run OR idle
