Sponsored by: CARiD
1991 Toyota Pickup
Old Sep 8, 2010 | 07:24 PM
Cpt_Buckout's Avatar
1991 Toyota Pickup
My truck was running and it started to take longer to start and longer and harder to start as in turning over. Now all it does is turn over and wont even try to start. Any ideas on what is causing this. No Fuel, no fire or what? This is my first Toyota so I'm blind to them. Thanks in advance. Junior
Old Sep 8, 2010 | 07:50 PM
DeathCougar's Avatar
You are going to have to give us more than that to go on.
"It won't start" is awfully vague
Old Sep 8, 2010 | 08:02 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Is your truck bigger than a bread box?
Srsly... If it's EFI, you can jump the B+ to Fp, or reach in the AFM box and move the flapper. You'll have to have the key on to do this. And cracking the cold start injector is how you make sure the (fuel) system's primed...
So make sure if you crack the cold start, you are where you can disable the method you used to test it, fast.
Then fire... Go to harbor freight or Sears, get a spark plug tester. When you see it, it's directions on use should be self explanatory...
Air: Make sure it can breath...
Search "Toyota" "FSM" or "factory service manual" and find one on-line, download it, and PLEASE read the thing like a Stephen King novel...
Next is a compression test... While yer at Harbor freight, get you one.
Old Sep 9, 2010 | 03:27 PM
Toyota's are a bread box. lol You turn the key to start it and it turns the motor over and never starts.
Old Sep 9, 2010 | 07:11 PM
peow130's Avatar
Seriously?
You couldnt be any more vague.
We need details
Is this truck a V6, a 4 cylinder?
Auto?
Manual?
4wd?
2wd?
We cant help you unless you give us these details.
Sorry if i'm rude, but, this is as bad as saying
"Truck dont start, what do?"
Old Sep 14, 2010 | 05:33 PM
It's a 4 cyl. 22re, Manual Transmission, 4x4.
zd92655
Mar 6, 2022 12:58 PM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
bprice0077
Jun 25, 2015 07:36 AM
