View Full Version : Newbie Tech Section
- Time to be geared and locked
- can i install a Aussie
- engine performance
- 1989 3.0 code 11 question
- will the 3.4L bolt up to the 95 3.0 4runner?
- Need some guideance on where to find parts!!! and info
- What else to change for 97 4Runner 3" LIFT
- Source for inexpensive OEM parts?
- Marlin Crawle Bumper with lights?
- radiator compatibility question
- wide tires on stock toyota wheels?
- Toyota Pickup 4 cylinder better than V6? Why?
- first car-2006 4runner lots of questions
- rear brakes self adjust on 97 Taco? weird feeling in pedal
- 85 pro comp lift
- 89 to 85 engine swap?
- how do i take the stock grill off?
- Sas
- dash board and guages swap?
- weber 32/36 probems, again!
- timing problem!
- '05 4Runner gas tank size
- Spare Tire
- Where to buy synthetic gear oils
- 22re re-build question
- transmisson name question?
- Birfield Eliminator kit vs 4330 Birfields
- 2002 2.4L Tacoma help!!!!!(first time poster)
- call me stupid but....
- Basic Lift. missing anything?
- Always P/S fluid instead of ATF??
- Question about a Lift Kit, please let me know your opinion.
- How much lift needed to SAS a 4runner?
- Differential Gasket from Checker for 7.8" Axle?
- where to get a larger radiator
- Proper Tire Inflation
- swapping leaft springs from bottom of axle to on top?
- bed pushed into cab
- Noob that needs to know where to start
- Gas Mileage
- Tire & Gear Size Help!/ It's kind of long but please read my situation
- RUF Setup
- Rear OME901 lift question
- lift questions
- what are some of the coolest mods you have done?
- 89 4runner no start
- rear locker
- body lift for 1991 p/u
- Best Online Dealer / Source
- Custom Front bumper dimensions
- Stuttering at 3500 rpm in 02 4runner
- suspension repercusions?
- adding 2inch body lift to the runner
- chevy s 10 blazer wheels fit on toyota?
- '84 front clip onto an '83?
- No oil getting to the oil filter?
- 87 4runner and warn bumper
- Need advice on 87 4runner
- Axle to Axle length?
- Info sources for 5vzfe rebuild/swap
- 93 toyota v6????
- 87 4Runner newbie and I need advice
- allpro hybrid front axle seal???
- rear disks set-ups????
- Auto Transmission
- body lift recommendation
- Shifter bushings number for r150?
- Best Motor oil for Toyota PU
- Vented rotors messed up?
- axles?
- I cant figure out if my ac/heat backlighting is connected to the 2 120v aux outlets?
- Front locker in the snow?
- 87' Oil Pan swap
- 22RE Oil Burning Question
- Need a how-to on changing diffy oil
- Newbie needs help with 94 toyota 4x4!
- will these rims fit a 97 4runner?
- looking for rear window parts
- thicker oil
- no spark
- Gears for 33's
- any good Toy mechs in the 972/214?
- overbore head gasket
- Trail Gear sliders.
- rear seal 22RE
- MLS head gaskets
- Thoughts on polyurethane bushings (Energy Suspension, Daystar).
- FJ 80 parts, what can I use??
- Can I combine these two 4Runners?
- Post Pics Of Your Bumpers!!!
- u bolt flip kit
- Replacing ball joints
- Have spark, have fuel, won't start...
- bushing
- 4Runner front doors/pick up doors
- crankin the torsion bars???
- how to improve IFS???
- 37s on a 1st gen
- What length of bolts for a 2" body lift?
- How much cutting to instal a Detroit LS in a Toyota axle
- 87 4runner lift question
- 3vze, bought a reman engine and something is not right
- Question about windshield wipers...
- Driveshaft for SAS question
- Where to Buy a Heater core?
- REAR bumper question
- Solid rear window
- Body Lift- disadvantages?
- Removing seats/storage in '06 Access Cab
- 4x4 clunk please help
- gear question
- anybody heard of this before?
- Excessive Valve tapping
- SR5 gauge cluster
- Installing a second battery in the rear of a '00 4Runner......
- SAS Question
- 86 22r Carb Issues
- Transmission Problem (only mode of Transportation)
- Home made lift kit help???
- 1996 4runner 3.4l tune up - specifics
- rings wont seat
- GM alternator bracket for 22R?
- High idle, delayed kickdown, occasional stalling
- Worst gas mileage the 22re has ever seen?
- helix power tower throttle body spacer
- Aisin hub gaskets and o-rings only-Where to get them?
- o2 Sensor
- front and rear 8 inch third interchangable?
- bed liner on the floor
- Do you have to re-gear for 35s?
- Do I need a differential drop?
- where to find my IAT?
- IFS to Straight Axle
- HELP! new rear leafs, now drives awful!
- motor n tranny swap
- 2000 4runner transponer key no workie, programing help?
- any toyota PU/4Runner seats sale??
- Engine Swap
- 4Runner/Tacoma Drivetrain Compatability?
- trucks runs rough
- 86 4 runner not starting
- How high is to high?
- 99 Civic Seats
- 94 toyota 3vze water bypass
- need help 87 runner turbo questions!!!
- 1-2 inch 4crawler lift???
- Coolant drain question: engine drain clock
- Trd Supercharger
- California Approved catalytic coverter?
- hey guys I need some help!
- V6 engine replacement
- 63 in springs?
- Blown head gasket feedback!
- Running hot Only while driving.
- Something Fishy
- 2001 Tacoma slips out of 4wd
- Odometer does not work 93 4Runner
- What are your thoughts on a lincoln locker in front?
- 1992 4runner Rough Country Lift!!! Bad Idea? Doesnt seem right!!
- Clutch... Its about time!
- air flow meter
- I Need Motor Help With head gasket!
- difference between 4lo and 4hi with tranny in low?
- CV Boot question
- poly body mount questions.
- What GEARS & TIRES are you running?
- new to the runner crowd.
- 81 front bearing re-pack
- 80 yota needs help!
- 1970 fj40 starting issues
- 22RE strange flux
- SAS for my 94
- Trail Gear wheel spacers
- 1980 Wheel Bearing Advice
- wiring harness question
- 1990 4runner Fuel Tank Sending Unit
- blowing fuses no power wont start
- Diff lock question...
- Speedo cable issue
- weber 32/36 flooding?
- motor
- trans oil
- Driveshaft is really close to gas tank
- Tired of flip flopping and losing sleep - LIFT ?
- Where to install and buy lift kids for Toyota 4runner 2000
- transfer case gears
- How much lift to run 31" tires?
- wireing issue
- which gears are best
- Suspension lift question
- 1995 4runner rear window issues
- Toyota Pickup 22re house cleaning
- New Member: looking for parts and ideas
- Removing lockers?
- Bumper Preparation
- replacing a brake caliper please help =(
- '88 toyota sputtering, Bigger carb?
- 87 Toyota Dually--- IFS or SAS
- 4.56 or 4.88 gears??
- Radiator issues 92' 3.0EFI
- 94 v6 A/T light
- Re gearing
- ball joint spacers?
- Is this what a bad rad looks like?
- Easy fix to axle twist?
- Should I regear?
- 1986 toyota pickup
- 20R M/T Bellhousing Bolt Problem
- Leaking T-CASE HELP!!!
- 22re drivebelt change
- Changing front axles...what all is needed?
- Toyota part numbers
- 1998 to 1999 front bumper swap?
- Fixing hydraulic jack in engine hoist
- timing chain tensinor promblems
- Failed Ca Smog
- no reverse back lights
- What's missing in this pic?
- interior/ sound system
- Newb checking in under guise of brake question
- 1984 22R rebuild?
- Auto Tranny... To flush or not to flush?
- Can't get parking lights to turn on
- 3vze head gasket rebuild questions
- Axle Nut Size
- 1985 sr5 prerunner info wanted
- 1988 toyota help
- Welded Rear Locker
- is it the same
- front axle
- What year swap do i have ?????
- knocking noise when turning
- home made fender flares?
- Which Springs?
- sliders before or after body lift?
- 2nd gen rough country lift!
- Muffler choice?
- Deaver Rear Springs 1st Gen?
- Source for 16x6 wheels/rims?
- Models and years or TRD E lockers and stock 4.56
- 15" Rims on 4th Gen 4Runner ???
- 08 4Runner - Aftermarket seat heaters and new foam...
- 4cyl gears in a V6 diff?
- 1987 sr5 22R carb 4X4 she is tired
- What do you recomend?
- Yukon locker
- 2jzgte
- Differential fluid change
- remove truck bed
- How difficult is it to replace CV shafts?
