PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. Sequoia In Dash Nav Question
  2. Thicker Oil = Oil Seal Leaks?
  3. Tubular Bumpers anyone?
  4. Suspension/Steering Noise - Idler Arm?
  5. Rear Toyota axle swaps
  6. doug thorley headers install need help (have pics)
  7. what kind of transmissions are these???
  8. Sirus/Xm
  9. 4Runner add-a-leafs.
  10. questions about new exhaust???
  11. egr from 87 22re compatible with egr from 93 22re?
  12. rear differential issue
  13. 22R/RE differences given it is same year
  14. 2002 Highlander - clock went out and A/C is acting crazy
  15. 1995 tacoma headlight wire diagram
  16. E-Brake Problems.
  17. noise after 22re rebuild.
  18. idle issues 94 DLX Ext. Cab. V6 5 SPD.
  19. lc 8wrap setup?
  20. 2001 Toyota 4Runner Charcial Canister - Used Part Help
  21. Clutch Diagnosis
  22. repair or replace?
  23. vortec 4.3 v6 engine swap
  24. Flush a/c?
  25. What year A/C will swap...
  26. 87 4runner help
  27. 22re temp sender, thermo switch.....
  28. Shielded wire question.
  29. Easiest way to diagnose a check engine light?
  30. Body repair people - I have a Body repair question..with pictures
  31. A/C Induced Power Loss
  32. length of round tube/ dom
  33. Frame Swap?
  34. Anyone tried Monroe Quick Struts?
  35. A/C won't stay cold, any ideas why?
  36. 1st gen bed on 2nd gen truck
  37. O/D Light stays on
  38. Bad frame 85 toyota 4 by
  39. Rear shock removal ?
  40. DRL's on 2001 4Runner
  41. 87 Runner rear diff/third removal question
  42. front diff breather extension
  43. 82 yota trans problem
  44. Flex?
  45. Starting issues with my 22re moter
  46. Tires, speedo's & gears (Oh my!)
  47. ISR?? What the duece is this stuff?
  48. Bed Accessory Suggestions
  49. Trouble with 93' S1 pickup tranny
  50. Question on 1986 Toyota 22re
  51. a/c charge amount
  52. Engine swap options for 3.4 owner?
  53. Exhaust Compatibility 2000 4runner
  54. Engine swap???
  55. Trusted 22RE tech in San Jose, CA area?
  56. Shifter Question
  57. Looking for suggestions as to what to do with my 22R
  58. 1st gen 89 runner 5peed swap info needed.
  59. Newbie needs help with 04 rough idle
  60. Just purchased a 2000 4runner ltd... any suggestions for wat to replace/upgrade?
  61. Front and rear bumper install
  62. 3.0 power steering pump
  63. can i turbo my v6?
  64. What gears do I have ? G252
  65. tundra brakes on a 85???
  66. what tranny
  67. 22rte 22rte swap is RUNNING !! Stock AFM running rich
  68. Axle removal questions on an "85
  69. Is there a gear change Video ??
  70. what are these
  71. Brake lights only work when they feel like it
  72. Will a Brush Guard from a 2003 Tundra fit a T100??
  73. 86 4runner rear bumper
  74. Recharging my A?C on 2003 Toyota Tacoma
  75. how many splines- rear axle
  76. New Headlight bulbs?
  77. 32x11.5x15 tires too much for stock 22re auto?
  78. A little bit of wiring help???
  79. Tire help
  80. Advice on cab swap...
  81. What weight oil should I use?
  82. PU lifts? cheapest lifts, body?
  83. Pickup 3'' lift
  84. cowl hood
  85. 4 banger buck!
  86. 98 T-100 Cyl head removal questions
  87. Advice on shocks
  88. Changing out the diffs.
  89. 86 4x4 pickup RIPPER
  90. Need help on wider fender flares
  91. no gas in cylinders? why
  92. Interchangeable A340F's?
  93. accessing dash bulbs?
  94. SAS customer service results
  95. Estimate on repair work
  96. Roll cage
  97. new toyota owner
  98. Post your photos of 3 inch lift with 32" tires
  99. Alignment get thrown off when engaged in 4x4
  100. New truck need help!
  101. Which windshield fits ?
  102. Hooked my battery up backwards
  103. Transmission cooler TOO big?
  104. Newbie question (Gears)
  105. 2002 tacoma pulling right when braking
  106. Driveline noise issue
  107. Questions
  108. 99 4Runner D/S Seat Frame.
  109. 1990 Engine Swap - Weak spark???
  110. Opinions on '87 4Runner Suspension Options
  111. 3" body lift 1988 pickup
  112. 2" body lift with 33x12.50s?
  113. 88 4runner what is this part?
  114. 33's or 35's??
  115. '99 4Runner LTD 4x4--upgrade options on a budget
  116. 96 Tacoma Drivetrain
  117. ABS/Brake fluid loss
  118. 92 v-6 engine swap
  119. Power locks do not work
  120. 2003 Sequoia Idle Rough
  121. new to me
  122. ecu malfunction?
  123. Gear oil Weight for 3rd gen?
  124. Front wheel arches with 33's
  125. spark plug wires from napa
  126. trailblazer?
  127. Ignition Tumbler
  128. 1st Gen pickup setup sugestions (HELP)
  129. VSC warning lights on
  130. transmission shift linkage
  131. BJ spacer with aftermarket A-Arms
  132. Towing 1,800lbs 1,200kms with 285s...
  133. TJM / ARB bumper identification
  134. New rebuilt 22-re (85-95) **BLOWN**
  135. Need brake service advice
  136. Torsion Bar ?
  137. auto or manual
  138. ect pwr light, manual trans
  139. 22RE wiring harness questions
  140. Learning the Ropes: '04 V8 4X4 4R
  141. Best Brake Pads?
  142. unanswered questions
  143. suspension and body lifts, wider A-arms, fast-travel shocks, and what if's.
  144. how hard is a 90 to 93 swap?
  145. Power Steering Problem
  146. rear differential - what's the hole for
  147. Yeah Rad blockage I love it.
  148. 95 runner lift questions
  149. transfer case oil/fill plug
  150. mud-less rear bumper suggestions.
  151. 89 2WD front suspension question
  152. thinkin of replacing stock 5 speed with w56
  153. need a new clutch!
  154. 1985 22/re 4x4 pick up starting issue
  155. 1st Gen 4Runner Spoiler or Wing
  156. Advice on paint and compressors
  157. Been a lurker for awhile, finally have a question about Bilstein shocks
  158. second gen body work
  159. engine problems
  160. 3vze Power steering odd question
  161. Tube bumper
  162. Leaf springs to short...
  163. Oil filter change on 2000 3.4L
  164. new guy here (newbie)
  165. 3.73 Gear Trouble
  166. wheel spacer or new wheels?
  167. Factory 4.88 drop in?
  168. as reed valve seals?
  169. Is it worth it? Blown Motor-Fix truck or scrap it
  170. Cleaning out 22RE EFI?
  171. Kit or piece together
  172. 87 22re ECU
  173. MY rear end has lots of backlash. How hard is it to fix?
  174. How do I replace a clutch in my 86 4Runner?
  175. 22R Vac lines
  176. Smittybilt bumpers
  177. power seat mod
  178. big 3VZE advice!!
  179. take a pic of your vac lines?
  180. 4WD engagement issues
  181. Brush Guard Lower the Front Height?
  182. Picking up the 1988 4runner at San Diego!
  183. 85 tire size
  184. 4runner driveshaft lubing - which grease?
  185. Fix or buy a new transmission
  186. Where can I buy one of these?
  187. Front diff. pinion spline count 23 or 27?
  188. How fast can I go with only a front driveshaft?
  189. Very Strange Gearing / Tire Calculations
  190. HELP! pro comp lift on my 1991 runner
  191. Sputter at 3000 rpm
  192. Suspension Lift for 98 SR5 4Runner
  193. leveling out?
  194. 3vz idle
  195. Wont Run NEED HELP
  196. T-case making noise
  197. Squeaky Noise
  198. 1990 4runner --> p/u cab swap?
  199. Automatic transmission
  200. I have brake issues
  201. Newb replaced HG for a 93 4runner 3.0 can't seem to get it right!
  202. Manual hubs...
  203. 22R problems!
  204. DEATH RATTLE in my Landcruiser axle 4runner
  205. Engine moise after new Head Gasket
  206. what to set pinon depth at on 5.29s
  207. 33's rubbing
  208. A/C Issue
  209. Top Plate Spacers
  210. 3 inch Rough Country lift
  211. 22r engine install
  212. Disengage the rear diff
  213. wheel hop
  214. 22re engine
  215. Ye old 22re timing chain guide subject
  216. 2 (probably stupid) questions about balljoints.
  217. Which Winch would you recommend?
  218. need help choosing a lift kit for my 89 4runner
  219. DIY smoke test???
  220. Truck shakes violently when going over bumps
  221. axle spline question?
  222. Toyota E-Locker Compatibility
  223. Performance Chips
  224. Fiberglass fenders installment
  225. How to remove whole dash?
  226. Proud Newb with his freshly acquired 93 4runner
  227. suspension combo OME/Bilstein on 97 4Runner
  228. sluggish, less throttle more speed
  229. Help please 4runner not moving, only in 4LO
  230. fuel injector questions
  231. will 86 IFS shocks fit on 85 w/ solid axle??
  232. Pre-Runner Bar help
  233. question on front axles
  234. Tips: 22re oil change
  235. p0420 question
  236. Re-gearing the diffs
  237. 90 4runner automatic to manual swap
  238. help with leak!!
  239. Limited slip Diffs
  240. 22re swap any advice
  241. 2wd lift HELP
  242. 22RE-GM Alternator swap - Give me the run down
  243. Lift question
  244. Front strut options
  245. Timing Chain
  246. Help timing an 89 22RE
  247. Speed Sensor Question
  248. New guy looking for 3.0 help
  249. body swap question
  250. 89 Toy PU 22RE with assorted issues
