PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. Need help.
  2. Fuel delivery gremlins
  3. Leaf springs
  4. Any clue where this goes?
  5. back up cam/truck-rear view cam/trailer
  6. Head gasket leaking a lot of oil
  7. Can a damaged cam be replaced without doing the head?
  8. Accidently ordered a vacuumless distributor
  9. T100
  10. Where do you find body armor
  11. 96 2wd tacoma
  12. interchangeable suspension?
  13. Are these factory Toyota wheels? If so what year?
  14. 1989-1995 Toyota Pickup 4cylinder/ 6 cylinder differences?
  15. Fuel pump runs when ignition off
  16. 89 4x4 rebuilt missing vacuum lines HELP
  17. idle racing
  18. not starting/need major help
  19. 84 yota dual t case options
  20. Vehicle windows
  21. Rear bumper
  22. Swap 1986 22R (carbureted) into 1983 22R (carbureted)
  23. 22R Intake/Exhaust Reversed?? HELP PLEASE!!
  24. 3rz-fe - CEL Bane of my existence
  25. Where do i buy lifts an diesel engines and everything i need
  26. 3evz engine and trans question
  27. ZUK mod?
  28. 87' 22RE sputtering with accelerating.
  29. MAF Problem with Cold Air return
  30. transfer case problems
  31. 97 T100 5VZ-FE new gaskets from heads up
  32. 22R Timing backwards?
  33. Sensors on My Dashboard
  34. Want to swap out AT for MT, whats involved?
  35. Smoking Alternator
  36. 82 exhaust manifold heat shield
  37. 87 4Runner Sr5 Power Windows Problem
  38. Looking for some parts for my 88 Toyota
  39. Trying to learn to set up my front suspension
  40. Source of oil leak on 98 4Runner V6 LTD
  41. 22re 22rtec interchange
  42. What is this bracket
  43. 95 3.0 no start help
  44. V6 What year to what year?
  45. Custom Exhaust: In/Out diameter of stock catalytic converter?
  46. what years of land cruiser rims will fit 2002 4runner?
  47. 1992 sr5 no start. I searched also...
  48. 88 3.0vze won't stay running or start hot
  49. 94 3.0 EFI oil in coolant after head gaskets done
  50. Camo wrap
  51. wth is wrong with my trans?! (video)
  52. $ rolled 99 tacoma 116xxx miles
  53. oile leaking 3vze
  54. 87 4x4 pickup 22r
  55. 97 tacoma rear end problems grinding and making a awwwng awwwng sound
  56. 1995 t-100 3.4 need help
  57. 1991 4Runner 3.0 A/T. Returning to previous glory?
  58. 1990 22re rebuild bugs
  59. Picking up a '78 4X4, big things to look for, general thoughts? ?
  60. Help with order of build - what should I do first?
  61. 91, 22re, 4x4 pickup
  62. Bad cv joint or ?
  63. t100 spuders once put into gear
  64. Oil in 22r stock air filter box
  65. Buy a Dedicated Wheeler or Use DD?
  66. 89-95 Air ride suspension
  67. Traction Control with 4x2 vs 4x4
  68. 22re wont start
  69. 3/16 Wheel spacers
  70. backspacing-fender flare fit?
  71. LIft Kit help/advice.
  72. 85 4 runner fuel pump problem
  73. 22r weber carb conversion
  74. Please help!!! 95 4runner 3.0 problem
  75. 87 4x4 pickup
  76. 1986 auto transfer case in a w56
  77. 89 3vze 3.0L 4x4 toyo pickup basic upgrades?
  78. 86 pickup turn signal nightmare
  79. 22re manual Trans fit in 96 taco ?
  80. birfs assembly
  81. waterproofing the interior fuse panel
  82. Fluids - Front/Rear Diff's, Transfer Case - 75W-90
  83. Front Lockers...
  84. temperature gauge @ 1/2 always
  85. Towing with a 89 Pickup.
  86. 1st gen 4 runner brake upgrade
  87. Spare tire
  88. Need a 3.0 engine
  89. Head Gasket Repair from a Beginning Mechanic Perspective
  90. weird idle
  91. 01 4 runner hood latch stuck closed
  92. popular engine swaps
  93. Climate controls
  94. Muffler part help
  95. clanking noise from rear end?
  96. No oil pressure after oil change.
  97. Very loud vibration eminating from transmission
  98. noob repairing frontend of 87 2wd pickup and having some trouble
  99. shorty headers 2003 4runner 4.0l
  100. Redline Gear Oil for '98 4Runner
  101. 1st Gen Taco CrewCab Pre-runner Transmission swap
  102. Ways to clear engine bay and lighten 87 22r Pickup
  103. Simple under bed tire mount ideas?
  104. 4.88 Gearing Help
  105. fuel pump bracket help
  106. fuel pump bracket help
  107. '86 4wd Pickup carb hesitation/fuel filter
  108. Tires and lift
  109. What sensor is this?
  110. 1995 4Runner Rear End
  111. 22r slight surge when hot
  112. Advice on a 84 pickup project
  113. Oil burning smell but no smoke.
  114. Lift Kit Help
  115. Upper ball joint hitting coil spring
  116. I have a problem with getting any power
  117. 78 yota chinook 20r
  118. Ticking noise coming from 3vze near distributor. Truck has no power unless advanced
  119. can my mpg get better
  120. Leaking lines - 87 4Runner SR5 4WD
  121. 04 Taco - clutch hydro system issues
  122. just to say hello
  123. fix it or throw it
  124. 2006 tacoma air and heat knobs
  125. R150F transmission 1992 4WD
  126. Please help.
  127. EGR Valve
  128. 85 4runner clutch release bearing
  129. 2nd gen 4runner 22re sr5
  130. Leaky wheel Cylinder
  131. Toyota Flatbed
  132. Spartan Locker concerns
  133. clutch question?
  134. speedometer Question
  135. 94 yota 4x4 brakes
  136. I NEED MORE FUEL: Kenne Bell Boost-A-Pump for 2001 4Runner SC'd??
  137. 3rd Gen 4Runner SC'd-- E L Prototypes ECU Upgrade??
  138. hj47
  139. 94 4x4 body or suspension lift
  140. Clutch problem plz!!! Help!!
  141. 3rd gen brakes on 2nd gen truck?
  142. 1985 4runner tag lights
  143. 1984 pickup carbeurated, thermo S/W ??s
  144. 97 toyota t 100
  145. 97 toyota t 1oo
  146. need to advance my timing on my 22re
  147. Sudden stall and still won't start 24 hours later...
  148. Lift kits for around $600?
  149. Cat to muffler gasket
  150. 88 fj62 fuel injeciton
  151. grind/knock w/defrost/heat
  152. Help passing emissions!
  153. 88 yota head help
  154. 22re i have spark and fuel but doesnt run
  155. 2001 Tacoma won't start after rain
  156. 81 5 speed help please
  157. zero point calibration
  158. 22r Bogging in 3rd
  159. cold start injector time switch wiring question
  160. 22re timing cover leak repair
  161. Is this too much rust than its worth?
  162. 4cyl manual trans. slipping with only 28kmiles
  163. Check engine light @ IHOP
  164. 3vze dosent keep its idle and runs rough
  165. need pressure plate torque specs for 88 toy pickup
  166. Aussie locker??
  167. 1994 yota p/u newb w/questions
  168. Distributor swap help
  169. Another possible 22re knock.
  170. noise in front end after locking hubs
  171. Power Steering Fluid Smelling Burnt
  172. Problems w/t 3vze
  173. 95 4runner wont move in neutral
  174. 4.56 3rd
  175. ome springs and coil spacers
  176. Max Power from a 22re
  177. Shocks for 1995 Toyota Pickup - Suggestoins please??
  178. Just got a 2nd Gen Tacoma after having my trusty '93 22re for years
  179. HOW to convert a 2nd gen 4Runner from 2WD to 4WD??
  180. need help
  181. 93' 4 Runner Speedo issues.
  182. 22re rebuild kit
  183. spitting and sputtering after warm up
  184. V8
  185. Gears and Tires - Daily Driver
  186. Should I get new tires or switch to ARB Locker
  187. Motors
  188. 1996 Tacoma rear end locked!!
  189. Rust in fuel rail and lines (tank cleaned)
  190. SFA Rebuild, spindle damage, leaf hanger questions...
  191. 94 4 runner best way to lift?
  192. Coolant bypass?
  193. 93 pickup 2wd rear shock questions
  194. 88 4runner 22re Stalling
  195. 1995.5 Tacoma?
  196. 81 1l diesel in an 85 2wd Cab
  197. 22r cooling system diagram
  198. Lifting 94 runner
  199. Help with 93 landcruiser rough/weak running and idle
  200. please help!!! 3vze not getting fuel after new injectors
  201. new guy withidle problem linked with coolant. weird!!
  202. efi fuse popping
  203. 79 yota help
  204. '93 Land Cruiser Engine Light Issue
  205. 3vze overheats at low rpms going uphill
  206. Bearings replaced?
  207. Limited slip diff for my 2001 Tacoma 4x2 Xtracab
  208. rearview mirror keeps falling off
  209. how to make battery wiring simple as possible
  210. what transmissions are compatible with my 20r engine in my 76 pickup?
  211. 874runner 22re runs rough when it rains?
  212. 89 22re 4x4 pickup Stumbles horribly when warm, alternator?
  213. Newbie needs advice/specific info on t-cases for 1uz vvti swap
  214. Marlin clutch??
  215. 95 3.0 4Runner CEL (check engine light ) suggestions?
  216. 86 Transfer Case Gear Oil Leak
  217. tacoma lift kits
  218. Check engine code 25,26,51. 89 22re pickup
  219. Rod cap Torque specs. I did check my FSM!!
  220. 22re rebuild and the machine shop
  221. Any good headers for 22R motor?
  222. Yota' noob in need of help!!!!! (1979 20r or 1983 22r???????????)
  223. Gauges and windows stopped working
  224. Aftermarket header O2 guidance
  225. how do I replace my thermostat on my 22RE?
  226. 85 22r yoter not getting fire out of coil
  227. Will 2000 Limited Hood fit my 2000 SR5?
  228. Headlight bulb retaining clip
  229. 22r Catastrophic Back Fire Advice
  230. 93 PU 3.0 V6, 5 speed manual: speedo sensor going bad
  231. Power Steering Pump Problems
  232. My 1988 Pickup / 1988 FSM discrepancies.
  233. Power steering
  234. Unlocked IFS axle shafts turning, '91 Toyota
  235. leaking power steering fluid question?
  236. 22re fan clutch removal.
  237. Fuel pump wiring harness location.
  238. Spark on Occasion - Seeking advice.
  239. Fix Engine Valves or get a rebuilt one?
  240. Heater Controls 1984 p/u
  241. 07 tundra loss of power no dtc codes
  242. New Shock help/ advice??
  243. Newbie lift question
  244. i have a question for you yota boys...
  245. 92 4runner a/t pistol grip shifters
  246. SAS question any knowledge would be great
  247. Interchanging parts from one yota to another
  248. Decisions regarding engine knock
  249. 83 yota power steering crankshaft pulley
  250. 3rd and 4th Gen cargo covers
