View Full Version : Newbie Tech Section
- 93 Front brake job
- bought me a toyota and is not charging.
- Rim and tire fit question
- The Age Old question!! SA vs. IFS
- 1991 4runner fender flares
- Tire size
- Should I be worried about my rear main seal?
- Water in Fuel?
- gas tank venting problem
- wanted advice on straight axle swap
- 3vze head gasket rebuild snafu
- Fuel pump replacement
- new (to me) 4runner, 02 limited
- Wanting Fiberglass parts
- 89 4runner wont start
- Name of part on 1994 pickup
- Brake booster
- Hub quality question
- 95 4runner 3.0
- 22re or the v6 ?
- Making 22r run on gas fumes. improve mpg
- Newbie hub question.
- checking differential 88
- 92 4 Runner 2wd front brakes locking up
- 93 pickup 3.0 manual lacking power - exhaust or other?
- 94 v6 4x4 pickup rear dif noise?
- 95 4runner buyer guide?
- aisin carburetor swap to weber
- Blew Front Diff on SAS'd Toyota, Can I Drive?
- Turbo on a 4x4 1993 toyota pickup 3.0 Engine V6?
- back yard paint job
- Wheel bearings. I hope...
- No power to the fuel pump
- Basic maintenance?
- Supercharger Whine Problem...bearings? (video)
- oil in coolant. blown head replacement
- Fixed position IFS??? Could someone please explain?
- Help- 87 22R starting issues
- sway bar removal pros and cons 88 4runner
- 2000 tundra exhaust manifold
- Losing Coolant Issue
- 3rd Gen Tailgate Change, Wiring Harness Issue
- Might be a dumb exhaust system question
- proper lubricant
- Frame Compatibility
- where to get longer/hd ifs axles for a 4in ifs lift
- Front Axle Help
- Engine light
- Brake warning light
- Coolant Leak!
- steering wheel tilted to the right, and pulling to the right after an alignment.
- 93 22RE Cruise Control not working
- driveshaft stuck to pinion flange
- Clicking noise in starter solenoid
- 22r valve lash adjustment
- High Idle issues with 1994 truck
- 4 link suspension?
- 96 4runner Available Option
- Easy yota MX
- R134a
- could a RTF swap be a economical solution for my problem
- Doing an SR5 cluster swap, will this oil sender work?
- 87 4runner..heard a pop now no power to the wheels
- g52-w56 transfer case compatability
- 4 speed transmission
- 22r Timing
- This might be a dumb question. 22re rebuild
- '93 4Runner 22RE throwing code 25
- Anyone ever use a engnbldr.com rotating assy?
- 22R exhaust headers, collector and pipe
- Fender flares and fuel door.
- Picking up engine to remove oil pan??
- 1990 pickup rear axle swap?
- 95 4runner VERY hard to start cold
- bucket seats
- Oil pump install - priming practices.
- Need help on lift kits 4runner 3rd gen SR5
- Misc cable??
- 1991 toyota pickup v6 temp gauge reading hot and gas gauge not working...?
- 98 4runner front diff into 93 pickup
- New newb
- How do you recharge the A/C on a 1991 toyota pickup 3.0
- Donor truck 22r into 22re?
- 94 4runner ifs bound after ome lift
- How to tell newly installed 3.0 from old 3.0 without receipts
- Need help pulling head gasket 94 4x4 Truck 22R
- Pulley wobble...fan clutch bad or water pump bearing? WITH VIDEO
- What radiator to choose?
- what is this part called?
- 3vze timing
- Toyota 3.0 mounting brackets
- Pitman arm Steering box nut size??
- 81 4x4 1 ton rear brake adjuster
- cooling system spike and pressure builds
- all new cooling parts but still over heating
- 84 4runner with a thrown rod
- CEL reading.
- New guy looking for advice
- air intake question
- Front crank seal replacement. Lubrication / sealant.
- Truck is having a hard time starting
- '94 Pickup Clutch Problem
- Exhaust manifold gasket leak
- 3.0 3VZE - Strange air intake noise...with video
- 95 toyota 4runner 3.4 swap no spark at plugs
- Moving on...3vze 3.0 Injector O'Ring replacement.
- 2nd gen t4r 3vze electrical issue.
- Engine trys to start but wont fire, newbie to this
- Ignition timing
- Strange Noise
- Exhaust hitting shock
- bad fuel mileage
- Fuse Block Wiring harness '94 4Ruunner
- 2000 4Runner Brief Hesitation on Low RPM Acceleration
- I'm new to this - 3vz 3.0 trouble removing crankshaft gear
- lift options for 33x12.50x17 (92 4runner sr5)
- Front turn signal connector, will an 89+ work on an 88?
- Post Temp Start-up
- 95 4 runner bucking?
- 86 Toyota Truck (Camper) oil leak 22RE
- Need help with water temp gauge and sensor
- Please help need advice!!
- 5.29 gear break in
- 03 Sequoia catylic converter
- Can I use Bosch premium filter for synthetic?
- removal of shell windows
- 3.0 overheating
- 3.0 coolant sensor conector
- Need Help with Wiring Harness in a 1986 22re
- First gen suspension problems, upgrade?
- frame bend/ hop help
- Bad ECM?
- Gear ratio for 88 Toyota with 35's
- 2nd gen runner fan explosion
- 96 T100 3.4 P1300 cutting out....
- '92 22re injection problem?
- Steering issues
- Funky Electrical Issue
- how to get bumper end off
- Need name if part.
- 2006 4Runner - New internal computer malfunctions 4x4 settings
- 1mzfe 98 please help //lexus//toyota/ es 300
- engine code
- Overheating
- Pathetically STOKED on 95 4runner
- 93 pickup body roll
- Useless OEM Parts on/under the Hood?
- HG going 4k after rebuild…1st timer. advice for what else to replace??
- turn signal no work
- CamShaft Sensor 2005 Tundra 4.7
- AC Exploded!!!
- Power steering fluid replacement?
- 81 toyota pickup will not idle!
- 22RE EFI Driveabillity Problem
- 86 to 95 Control arms
- Wheel lock up and bind in reverse if in 4X4 cut in
- Bent knuckle housing.
- Used 98 Taco, many questions
- Weber 38 Dgas
- Rear fender liner
- Swamped 85 and now runs awful?
- Value of 1991 Toyota Pickup with a 3.4L v6 + suspension goodies.
- IAC Sensor , BVSV(Bi-metal vacuum switching valve)
- After headjob no power to starter
- newbie from north ga. here!
- Compatibility issues when replcing stock ATF with synthtic
- Rack and Pinion on Early IFS
- front brakes not working SAS
- 1987 Toyota SR5 4x4
- 88 4runner
- 94 3vze running rich and killing plugs?
- Rust on an 88 toyota pickup
- installing rear leaf spring help
- Need T100 Diagnosis Help:Stuttering on Accelration and around turns
- would 98 tacoma 4cyl axles fit 98 4runner v6
- Head Gasket Replacement Walkthrough - '95 4runner
- 22re with high rpm rv cam
- 98 taco high idle, high rpms for speed/gear
- code 25 on a 91 4Runner
- 98 tacoma
- 86 Runner Brake Problems
- 92 toyota 4runner automatic locking hub problem
- 3.4 swap body harness help (must be driving by Monday)
- 88 22re Losing Coolant Overheated??
- 1989 sr5 pickup value
- 1st gen advice
- Where do I start?
- 96 T100 differential crush sleeve
- New tps
- Cruise issues
- no power to fuel pump
- Alignment / Wobbles
- 87 Pickup Aisin Carb Questions
- Newbie here
- 89 4Runner - Identify this engine electrical part
- TPS screw thread size and length?
- Newbie question here guys?
- Transmission Cooler Lines
- 81 pickup 22r overheating!
- Front hubs move to the lock position No 4X4
- 94 4Runner eating coolant, head gaskets recently replaced.
- Can't get fuel to the carb.
- Short block condition 22r
- Rims n Tires on a 93 pick up
- 3 Inch body lift with 33s help.
- Shock help!
- 2nd gen 4Runner poor MPG
- Newbie say Hi
- Burnt wires, wondering where they cennect to
- Please Help!!! Toyota Pickup Automatic Will Only Move in 4L! Thank You.
- Slipping gears
- 97 tacoma 5vze trd diff. locker relays location?
- Using low range with front locks off???
- toyota power gear box
- brakes are driving me crazy
- What to expect from new suspension? OME
- DUI Distributor 22r Install Details?
- looking for a 22r to rebuild-what to look for
- rebuilt 22r running not so great..
- '82 4x4 lb tow capasity???
- Newbie question- interchangeability
- Will parts off an 86 22re fit an 87?
- Mechanical Speedo Cable
- Heater switch fried??? 93 22re
- 1988 22 re wont start
- Pinion play front to rear? Push Pull..
- 4Runner Simple Questions....
- Front axle hub seal
- ID Tranny Via Part No. or Model Code?
- tow capacity of '83 4x4?
- 1983 Pickup Oil Light Question
- 98 tacoma tire size
- I jumped on a 3 liter grenade. Help
- '03 Tacoma v6 with High Miles?
- Head gasket or head?
- How can I tell if my Toyota pickup is a HiLux,Deluxe,Standard,ETC?
- low idol supercharger clatter
- Help with seats?
- 3rd member removal - elocker considerations?
- Sizes of starter solenoid contacts
- 1992 Pickup 22RE OBD code 31: MAF benchtests OK; What vacuum switches indicated?
- Intermitting hard starts and bad mpg.
- 1989 toyota
- Removing speedometer and Tacometer
- CEL Diagnosis
- 3.4 2wd auto
- Poor fuel economy on 87 pu 2wd
- stuck caliper and upgrading MC / dual diaphram
