Sponsored by: CARiD
1992 Pickup 22RE OBD code 31: MAF benchtests OK; What vacuum switches indicated?
Old Apr 14, 2014 | 03:17 PM
yotabuddy's Avatar
Vehicle has experienced first ever electronics problem at 293k miles. Sudden, severe stumble pulling away from traffic light. Engine at full operating temperature, Check Engine Light (CEL) flashed several times then went off after which it ran smoothly. Drove home. Checked codes: 13, and 31. Inspected and bench tested distributor ignition and Mass Airflow meter - found to spec. Cleared codes, ran perfect for five days only to give CEL flash once more with hard stumble, like key was turned off. Shortly thereafter, it would barely pull up grade and seemed about to stall out completely. It got me to my destination though. After cooling down and checking and clearing a code 31, it brought me back home seventy miles without a hitch.
I'm thinking the code 31 is pointing to the vacuum switch and not the MAF, but with only a wretched Haynes manual at my disposal I can't discover which vacuum switch is indicated by code 31. If this truck has a MAP sensor, I can't find it. I inspected all vacuum lines and connections in engine compartment and found nothing amiss. I searched the forums here but could not find this exact problem listed. Can anyone in the Toyota faithful help me out? Thanks :help
Old Apr 15, 2014 | 11:27 AM
combatcarl's Avatar
Over on pirate. http://www.pirate4x4.com/forum/toyot...1-not-maf.html
Old Apr 16, 2014 | 05:48 AM
yotabuddy's Avatar
Looks promising
Thanks, combatcarl. I'm looking into this solution and will post back here when my stumbling issue is resolved. Again thanks a lot!
Old Apr 16, 2014 | 07:53 PM
combatcarl's Avatar
No worries. I usually ignore all the routine "hey what's wrong with my truck" threads. But don't see people doing a little research before posting, so I figgered I'd help. Most of the stuff I turned up didn't have a solution. If you inhabit pirate at any point, definitely search well before asking questions.
sonic concepts
Aug 16, 2025 03:13 PM
Hatch man
Aug 25, 2021 12:54 PM
Sandman
Jul 23, 2015 08:15 PM
serenity03k64
Jun 27, 2015 07:59 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
