Sponsored by: CARiD
1983 Pickup Oil Light Question
Old Apr 17, 2014 | 11:00 AM
Douglasof8arms's Avatar
I'm new to Yota tech and I've got a question I couldn't find and answer for in the searches I've used so far. My 1983 Toyota pickup's oil light comes on after the engine runs for a few minutes. The light will turn off if I turn on the air conditioning, and it will turn off when I press down the accelerator but if I'm idling the oil light stays on. I checked the oil levels and they are not low, so should I start looking at my oil sensor? the oil pump? If anyone as a informed opinion or a educated guess I would appreciate the assist. Thanks.
Old Apr 17, 2014 | 12:42 PM
INFINITY's Avatar
it is a pressure switch on the block. when the oil pressure is not great enough to press back the spring inside than it grounds out and your light comes on.....bad switch, low oil pressure, or oil pump...
Old Apr 17, 2014 | 02:18 PM
Infinity does the pressure switch on the block have a name or part number I can look up?
And what would I need to look for to fix low oil pressure?
Thanks
zd92655
Mar 6, 2022 12:58 PM
GreenLion
Jun 7, 2021 10:49 AM
Aleeex_u
Jun 5, 2016 06:52 PM
paxanders
Jun 21, 2015 06:29 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
