View Full Version : Newbie Tech Section
- Brake issue, something new???
- How do you make a 22re a 22r???
- will an 85 22r head work on a 84 22r block
- will 32inch tires rub on a stock 89 yota pickup?
- hubs wont engage, but shows im in 4x4
- idle issues
- Ride Height of Stock 1st Gen 4runner?
- Oil consumption
- ATF in your T Case?
- Power windows
- homemade leaf spring shackles
- New member with motor problems!
- need info on parts interchange
- dumb battery cable question
- transmission and differential fluid capacities
- All Aluminum Radiator?
- 95 tacoma xtd cab engine swap!!!
- Got any tips for organization?
- 22re engine swap need some refrences...
- 1984 4Runner am I wasting my money on this parts list??
- Right Spring Sag
- How slow IS the 3. slow???
- Roll bar for pickup
- head gasket replacement on 3vze
- bad vibration while driving
- 3VZE Shortblock!
- Getting rid of air box?
- Valve cover gasket on, now it stalls ?? =/
- 3vz click but no start...?
- transmission installation hang ups
- gas tank lines?
- 22R cam
- Easiest motor and tranny swap for 1989 toyota pickup 2wd now has an 86' 22r
- 3vz bogging down under load with whistle
- how many of you are running more than 3" lift on the stock ifs set up?
- muffler replacement
- 92 4Runner will not start when hot
- Why not a spindle lift?
- 85 toy 4runner fuel gauge
- Anyone done a 3.slow to a 3.4?
- wil an elocker from 3.9 work with 4.1
- Popping noise while cranking the wheel hard
- T-stat replacement!!
- Which gears
- Power steering woes..
- Is this a good Alternator?
- 3.4 engine replacement
- problems starting up
- Control arm tips?
- New shocks, front/rear, size ??'s
- evap description
- Is my manual hub missing something?
- 2nd Gen or 3rd Gen 4Runner for TDI Swap
- How to wire up an electronic fan?
- Steering Rack Seal Kit
- 4 Wheel Drive won't engage
- 87 yota need help
- high idle on a 22re
- how do i change my front axle drive axle bearing??
- 88 toy not getting spark HELP!
- rough "warm" starts..'99 4Runner!
- 3vze radiator corrosion
- reviving an 82
- 22re bad gas mileage and bad throttle responce
- 1992 auto to manual swap wiring info needed
- A Quick Question About Heater Core Replacement
- 90 3vze 4x4 5spd xcab which trans do i have?
- Swapping ADD to Manual hubs?
- fluctuating idle RPM (sorta)
- Replacing fan clutch fluid with oil.
- key light?
- Gentle acceleration makes my 3.0 V6 stall
- grinding noise with hubs engaged
- 90 3.slow, bad mileage, boggy, fuel smell when cold
- opinions on running 36's with 5.29's or 4.88, hwy vs offroad
- heater blower wont blow
- Diff oil leak. Newbie-type question.
- Why do you need two transfer cases?
- 86 22re brake wire
- idler arm install write up?
- where the heck is my trans fill plug?
- does re gearing help with MPG's?
- What size socket for my wheel bearings?
- 3.0 v-6 3vze turbo kit????
- Lockers for BIG tires..
- What tranny model is this!
- Choppy acceleration
- Head Gasket Advice
- pre 88 fuel sending unit
- Knocking When First Cold Started
- 95 4runner 3.0 ECM compatibility
- Oil leak ??? 1995 4run v6
- My battery won't hold a charge
- Different sized spare tire
- headlight options
- Question about rear leafs
- Frozen bearings?
- Newbe Here 22r basic wiring to get it started
- how to test if the slave or master cylinders bad
- 90 4runner p/s box in 87 PU
- toyota transmission ?'s
- Video of my stock 93' 4x4 not making it, all kinds of questions
- vibration at highway speed
- 22RE stumbling issue
- Part Brand Recommendations for 3.0
- Toyota rim compatibility?
- 3" Body Lift help
- 1986 4runner Shock options PLEASE HELP
- Which Detroit eLocker for 93 4Runner?
- 3.4 v6 headers/power upgrades
- I need help installing a steering stabilizer on my 88 pickup
- Shift Console buttons and switch identification
- No spark
- 3rd gen 4runner back space question
- Advice on rear locker use
- Hose Clamps for Rad Hoses
- what happens when you step on gas?
- Too Good to be True??
- 93 yota pickup 4x4 22re exhaust question
- 22re #2 and #3 cylinders not getting fuel
- 1985 22re fuel line confusion. fuel supply, where does it go?
- Removing cone washers
- 89-95 2wd Pickup fabtech lift and coilovers
- outer tie rod end ??
- 5vz vacum hose routing help needed.
- Operating aisin manual hub conversion
- Need help!! How to remove and install bushings on pickup
- Loud shhhshhh noise in air intake
- 4wd issue
- 87 4runner transmission question
- 22RE Ebay Water Pumps
- water in intake maybe? why am i losing power
- 4 Runner rear suspension help
- Front end noises
- Front Diff Question
- 22RE removal, minimal parts removal
- What tires should I go with?
- Tire fitment question
- 93 SR5 4-Runner Valve Problem
- 4Runner lift??
- Coolant and oil mixing
- the unanswered question on rebuilt motors
- Need new shocks! please help!
- Auto to Manual Swap; A340 to G or W series
- newbie steering and lift Questions
- Will this work on my 86 truck?
- door compatibility for my 85' pick-up
- Options for replacing rear lift blocks
- Tips for cleaning Aisin hub parts
- 91 truck not getting fuel
- Tire Fitting
- No rear brakes
- Computer Issue?
- Body lift question - will I need new shocks?
- Just bought my 2nd 4Runner yesterday, and I have a ? re: guages/dash trim
- 95 taco bucking / missing under load
- Expert Advice- VW AAZ 1.9 Conversion Prep
- i have 2 30 80le trans will they interchange
- quick question before i buy a new head
- Loud poping noise comin from front end??????
- Neglected front end on 98 taco 4X4
- These are 5.29's...Right?
- Idle 1999 4Runner
- Replacing drive belts on 2000 4Runner SR5
- 97" electric diff in a 86?
- Stock height on 94 4runner
- Toyota factory wheel question
- Where does it go?
- 3VZ-E 3.0 Head Gasket Replacement in vehicle. Exhaust Xover pipe removal help
- Igniter Swap Needs help
- intake manifold cooling tube seal
- semi newb question 22re
- Standard/Metric Brake Line Fittings
- Problem NEED HELP truck keeps dieing out
- Spark plug gap?
- Stress from wider track with wheel spacers?
- engine swap years to avoid?
- 99 4Runner sas
- Shift boot 2010 tacoma
- lift plan
- 99 runner limited Diff lock
- Warn hs9500i
- Engine wont fire? - 1993 4Runner
- Which Zuk mod???
- Rear Main Seal Leak or Tranny
- PAINT/ body protecters
- 22re to 22r swap?
- Idk what i like better?
- HELP!! Need more than 4" suspension lift on 89 4runner
- 22re Throttle body accident! *help please*
- What does j/c mean on a EWD
- Offroading on 2 wheel Drive
- 91 22re loping idle
- power steering on an 87--how to add
- 87 Pickup Rear coil swap for leafs?????
- third members with 5.29 gears
- Brakes clunk and slip then fine???
- tranny problems!
- need help discerning diagnostic results from leak-down and compression tests
- 87 22r heavy idle drop
- Noob question: How long for a lift on an '05 Tacoma (non prerunner)
- need opinions on new 22re
- 85 smokes real bad until it's warmed up "really warm"
- Newbie needs solid axle info
- Which rear shocks to buy with 2 inch coil spacers!
- Newbie wants some lift info
- 3VZE Reman swap questions.
- Rear end sag on 94 4runner
- sas 4runner write up wanted
- 22ret questions
- 90 3vze aut0matic or 85 22re manual (HELP!)
- Steering box casting TOYODA
- 3VZE coolant leak into intake?
- difference in 20r and 22r engine
- 17's for an 86 IFS (and late sas) 4x4 questions
- How fast can I go with rear diff locked?
- 81 timing
- Ditching engine mods
- mix and match yotas
- G027 code 3.9 gear ratio
- 86 toyota pickup sr5 sometimes runs like crap
- Ring and Pinion Jig
- 3vze or 3vzfe which one do i have
- Whats the best way to build a front bumper to protect?
- tach install question
- Idea more bump travel?
- 22r rebuilt, wont run
- Shock Recommendations please
- Subs in 1990 ext
- Carrier Bearing?
- e brake handle
- 3rd Gen 4runner Front suspension lift question
- Ball Joint Spacers!!
- Craigslist Cluster
- all parts needed for timing chain gasket replacement
- Brake Booster Pump
- how to calculate torque specs in 4-lo/ double lo etc
- How to tell how high a lift?
- bumper brackets?
- best timing chain and head gasket kit for 94 with 22re
- First Gen 4runner shocks
- 22re enngine timing. Short circuited T terminal did nothing to the engine
- Newb question about Fuel Sending Unit
- Where is T Terminal to adjust timing
- How do i run fog lights w/o headlights
- Code 52 knock sensor?
- A couple quick questions
- is what i have a good start?
- 86' Toyota gears and lift
- What to do? After v6 to 22re conversion efi issues
