Newbie wants some lift info
newbie here, i have a 93 toyota PU. just have 30's on it at stock ride height, i was wondering what i could and can do to get a little 3 inch lift out of her without spending a pretty penny, i was thinking about blocking the rear end and getting the ball joint spacers that sit between the shock and the upper controll arm, i have always been a honda tech kinda guy but i got the truck wanting to learn more about offroading and gettin a little lift on her, any info is greatly app.
pat
pat
Hey Pat:
welcome to Yotatech.
FYI I moved your thread to newbie tech as this question gets asked a lot here.
we have a pretty good search engine here and a bunch of helpful members.
Give the search a try and you will be surprised what you find.
here are a couple of thread that will probably have some answers for you:
Newbie modification ideas:
https://www.yotatech.com/forums/f120...mation-121264/
IFS: what tire will fit:
https://www.yotatech.com/forums/f120...thread-213713/
86-95 frequently asked questions:
https://www.yotatech.com/forums/f116...-first-214051/
good luck and have fun with your yota
Yes:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ2
Possibly:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ1
will i need to get a longer shock on a 2.5 BJ spacer, all info on this would greatly help thx
FWIW, try to limit the amount of lift to the bare minimum you need for the tire size you want. This way you keep the center of gravity lower and the truck will be a lot less likely to tip, whether you're on the road or off. Also, stay away from lift blocks in the rear if you can
ok thankyou guys, i have not looked at the bars to see if thay are cranked up or not. how can i check to see if they are tightend, i looked at some pics, how many inches of thread should show if they are cranked up???? sorry im not advanced in this kind of subject LOL. and if i can squeeze maybe 2inches outa them then i might just raise the read 2in and put 32's on it. ???
ok thankyou guys, i have not looked at the bars to see if thay are cranked up or not. how can i check to see if they are tightend or is it like a pathfinder where u take the bracket off turn the rod and put it back on? sorry im not advanced in this kind of subject LOL. and if i can squeeze maybe 2inches outa them then i might just raise the read 2in and put 32's on it. ???
- http://www.4crawler.com/4x4/ForSale/...nBarAdjustment
13.5" - 14" is stock height:
As long as they are 15" wheels, the above measurement applies. If a larger dia. wheel, adjust accordingly (less 1/2" per inch taller wheel) and if any body lift, also adjust accordingly (1" more per 1" of body lift).
ok well i measured her and shes 13.5 on one side and a little under 13 3\4 on the other.
so now my question is.....
how far can i adjust to, can i take it to 15.5 ? or will it not allow it or is that not a good idea? and how much tightening will it take to get up there, will i touch the underbody before i get to the 15ish ride height or above?
i also took some pics to help. this is the torsion bar setup, looks a lil diff from the other post i read but idealy the same. and it only has one nut up on top.
and this is the close up of the bolt and again the ride height is right at 13.5 and i have about a half inch or a little more before it touches the underbody there.
again thankyou guys for all the help, i know yall have prob seen these threads alot but im just learning and need a lil extra help.
pat
pat
You can probably go up 1.5"-2" with the torsion bars, the higher you go the harsher the ride:
- http://www.4crawler.com/4x4/ForSale/...er.shtml#FAQ10
No your right. The bolt doesnt move, just the torsion key inside.
Spray that all down with some good penetrating oil before you try and tighten them.
IF you plan on offroading, you might not want to crank the bars. As you gain ride height, you also loose front end flex.
