Sponsored by: CARiD
Ball Joint Spacers!!
Old Feb 25, 2011 | 09:28 AM
BYoder92's Avatar
Does anyone know were i can order a set of 2 or 3inch ball joint spacers for a 1994 yota truck. I can not find them anywere on the web. I would really appreciate any help or other info. Thanks
Old Feb 25, 2011 | 09:37 AM
justin_4runner's Avatar
u can get them from ebay
or are u trying to find some that are 3 ins that u wont find, its like 2 is the thickest but u get 3 inch lift out of it with tightening up the torches bars
Old Feb 25, 2011 | 11:02 AM
BYoder92's Avatar
Thanks guys found what i need i think. my next question is how much of a ride difference will it make with the t-bars cranked up alittle bit, and will it put more stress on front end parts causing them to break eaiser. Jus wondering cause ill be putting this set up on my 94 daily driver.
Old Feb 25, 2011 | 11:05 AM
bobby_duce's Avatar
if its your daily driver most people relax there t bars alittle bit and it will give you better ride quality than if you cranked them.
Old Feb 25, 2011 | 11:10 AM
kiyobrown's Avatar
Crank the torsion bars hard, it will ride like crap, and puts a tougher angle on your cv joints, which could cause them to bind and/ or break. If you are trying to get that much lift out of it, time to think about a bracket lift. I got Spacers to level out the front end after the zuk mod, and ended up RELAXING the torsion bars about 3/8" and resulted in a softer, much nicer ride.
I then wrecked all that with E rated tires. LOL.
BTW, zuk mod and BJ spacers, you can fit 33's if you so choose, without a body lift. Not sure how big of tire you were trying to get in there.
Old Feb 25, 2011 | 11:17 AM
BYoder92's Avatar
Im only putting 32x12.50 AT's on it. My goal is just to lift it jus a bit to get rid of the stock look, cant stand the way it sits and looks now. Guess im gna go with 2" ball joint spacers in the front and blocks in the back and see how i like that.
Old Feb 25, 2011 | 11:56 AM
kiyobrown's Avatar
I'm sure a lot of folks would recommend longer shackles, new rear springs, add a leafs or even a zuk mod before they would recommend rear blocks.
x2 on the longershocks.
Old Feb 26, 2011 | 01:09 PM
Mudd Duck 1's Avatar
I have aftermarket shocks that were on my trruck when I bought it stock. They seem to be long enough with my BJ spacers and my add a leafs. No problems yet. I have the WABFAB BJ spacers, they came with the dif drop kit (witch helps reduce to extreme angle and strain on your CV's) I'm still runnin' 31's since mine are only about 5 months old, I didn't touch the tortion bars at all and it's great. The only thing I'd recomend is gettin the 1 inch drop spacers for your sway bar if you wanna keep it (I just removed mine all together). All in all I'd say this is the best bang for your buck lift option out there good luck.
EDIT: 1 more thing GET AN ALIGNMENT!!!!! It's pretty outta wack when your done, also if you wanna good write up on the instal check this link out
https://www.yotatech.com/forums/f116...riteup-201297/
Old Mar 17, 2011 | 07:23 AM
crazytoyota4x4's Avatar
www.krfabs.com/product_detail.php?productID=11
Old Mar 17, 2011 | 07:58 AM
tlrskunk's Avatar
you can fit 35's with 1.5 BJ spacers and 2 inch blocks in the back with a little trimming and some fender well massaging....
This is my old truck.
Old May 10, 2013 | 11:21 PM
-City Slicker's Avatar
hey i have a question..
i am going to use the 11" x 5" coils with an adjustable perch and a rubber riser '
(so plus 2 inches or so)
13" total spring/riser addition
& im gunna crank the torsion bars in the front for now
and maybe get 1.5" bj spacers
i am aiming for 1-2 inches above stock height..
i recently bought 4600 bilstein all around to install and now im wondering if i will have enough travel in the shock to accommodate the 1.5" - 2" of lift i want.
the other bilstein 5100 shocks call for 3-4+ inches.
am I safe with the 4600 bilsteins at 2" of lift?
Old May 11, 2013 | 07:17 AM
MudHippy's Avatar
For the front with 1.5" BJS
4WD Ball Joint Spacers
The following shocks are compatible with SDORI 4WD Spacers. These shocks have a minimum compressed length of roughly 10" and a maximum extended length of at least 15".
Rancho: RS5167, RS9272
Procomp: 317514
KYB: 565084
Doetsch Tech 3078, 8069, 9069
OME: N92, N98
Old Sep 25, 2013 | 04:03 PM
Originally Posted by crazytoyota4x4
any one use these , do they still require cutting the upper A-arm ?
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
