PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55
  1. Gas Gauge This morning
  2. Should I trade for this 88 toyota pick up?
  3. Best dual battery set up?
  4. spring?
  5. Just bought a 91 and I dont know what something is...HELP
  6. Does anyone Know a Good place to Buy Beadlock wheels?
  7. Driveshaft ???
  8. spark plug wire, placement ?????????
  9. Gear break in?
  10. Newb saying Hi!
  11. Would you attempt rebuild of engine?
  12. Confused about lifting my 4runner?
  13. Confused about lifting my 4runner?
  14. Will a 4runner top fit on a/my 86 pickup??
  15. New to website, any area to view photos?
  16. 3.0L 3VZE rebuild. I need help finding parts
  17. clear coat recal
  18. '03 4Runner ABS Computer?
  19. deckplate & intake silencer mods
  20. Another bogging/misfiring 22re question (kinda long)
  21. New guy saying hi with newb questions
  22. Moldy recovery strap
  23. 4Runner hesitating at 2K RPM - help
  24. Fuel Filter Location
  25. Band Adjustment/automatic tranny?
  26. Knocking Sound
  27. Should I buy this truck?
  28. Fixing a 4Wd problem: Will my fix be OK?
  29. No Spark 84 4runner
  30. 96 4Runner won't start
  31. Lysmachia - Blown head gasket?
  32. 22re driving and motor losted all power and start making noise
  33. If it ain't broke - don't fix it
  34. rear door not auto closing all the way
  35. Cheapest/best quality place
  36. A rattle is felt through the steering wheel.
  37. What are some things I could do?
  38. engine problems
  39. Driveshaft ????
  40. Rear Third ???
  41. 85 EFI runnin' rich ??? HELP!
  42. first tune up at 40k
  43. the best place to order a locker
  44. motor vs trans?
  45. High RPMs
  46. 3rd Row seats for a 1st gen
  47. another 2nd gen rear window!
  48. Yet another Headlight Question
  49. high beams won't turn on
  50. Rear ASB sensor in the third member
  51. Trouble locating "brain" for RS3000
  52. 94 runner 4x4 22RE oil pan gasket change?
  53. Automatic tranny slipping!
  54. Blown Engine swap out for a 91 4 runner
  55. Clutch Question
  56. I was thinking of an UPGRADE soon...
  57. Newb Tool Question!!!!
  58. EFI-Throttle Body Service
  59. Jack placement
  60. gear ratio question
  61. Leaf Spring Question
  62. Lift for a Newbie - help!
  63. mild lift but strong
  64. E-Brake Cable from Handle to Mid/ Where?
  65. Receiver hitchs
  66. Idle Issue
  67. Noise when not accelerating!!
  68. diagnosis help turbo or blown head gasket??
  69. Toyota V6 problems??
  70. Fuel injector issues
  71. 00 tacoma no start
  72. grilles
  73. Rattling engine
  74. Introductions and Hi!
  75. ok..i really need some advice...trail rig vs dd
  76. valves are aggravating
  77. 94 4ruunner 3vze
  78. Performance Headers for 22r, worth it?
  79. How to remove Gauge Cluster
  80. are 95 and 2001 4runner rims swappable?
  81. intake questions??
  82. Loss of Engine Electronics
  83. Another brake problem, 90 4runner.
  84. rear bumper removal
  85. Jumpig e1 and te1
  86. T-CASE shifting problems?
  87. 88 4runner fan pully problem
  88. Propane
  89. Best all round runner to buy
  90. 94 22re no start resubmitted in correct section(I hope)
  91. 22RE engine bog
  92. little help w/33x10.5 on stock
  93. problems after HG replacement
  94. Rear anti-lock dash light
  95. Trail-Gear
  96. Headlights work, but they wont turn on.
  97. What type of lift for "my offroad"
  98. Fuel injectors
  99. Aussie Locker
  100. 98 sr5v64x4 alarm chirp/foglight/autolocks
  101. How long should a battery last
  102. Recomended Octane level?
  103. how hard is switching to an elocker axle rear..
  104. messed up hg replacement.
  105. 4.7, where is cylinder 1? Anyone have a manual?
  106. 93, 94 swap
  107. MN winter and no heat
  108. Stock Suspension how big of a tire can i use
  109. Going to buy a 4runner which one?
  110. 1sttoyotaparts.com
  111. Cross drilled brake lines?
  112. nut came off my sway bar disconnect what is a replacment
  113. Holley 2brl on 22R throt linkage?
  114. New here, Questions
  115. Noob question- SR5 identification
  116. Driveshaft flange/ r&p
  117. 88 Land cruiser help
  118. stock yota needs new tires.... advice
  119. What is this red light on my steering column?
  120. wheels and tire questions for 89 p/u
  121. Need Help! 91 4x4 3vze
  122. clutch not working, Just installed engine
  123. 3vz-e Issues
  124. Help! Truck broke down!!
  125. Non-op Windshield Washer?
  126. ohmeter
  127. Locker questions
  128. 2.5in front and rear Daystar lift
  129. Alignment/diff. drop question
  130. Gas guage
  131. SDS EM-4 Install on 1994 Toyota Pickup 22re
  132. code 14 and 25?
  133. 85 2wd pickup power steering
  134. transmission change for 20R engine
  135. re-gearing on 1988 4runner
  136. which lines do i ask for rad.
  137. Idle increase - weird noise
  138. gasket question
  139. how can i flush out my wiper spray
  140. 03 Tacoma Humming\ vibrating sound???
  141. i wanna advance timing...need help
  142. Cheap Taiwanese Heads
  143. Spark Plug
  144. New Truck for build question?
  145. Obd Ii
  146. panhard brakcet/t-bars
  147. New guy looking to buy ... got some questions
  148. Idle Speed
  149. Bigger Tires: 305/75r16 on 3rd gen?
  150. Ring and pinion help. 91 v6
  151. Switching to 4wd fixes idle?
  152. new tires for the yota which brand??
  153. 20R/22R Distributor
  154. t-100 and tundra are the same truck?
  155. 3.4 conversion
  156. retreads
  157. Trans lines at radiator
  158. ECL and O2 sensor
  159. Sensor Cleaning
  160. need help OME lift kit install help.
  161. best way to lock front IFS diff
  162. efi out/carb in
  163. 22R sometimes wont start??
  164. swap 3rd member 1st gen with 2nd gen
  165. Stock Rear Diff Question
  166. i have a parts truck with a good engine.. best way to store it??
  167. What is the best buy for a 854Runner Lift Kit
  168. raining in vegas
  169. Body Swap?
  170. Fuel line question
  171. Any ideas
  172. Changing the ration on one diff and not the other?
  173. Another new noise! When will it ever stop?
  174. '95 Runner newby questions - i've read the stickies
  175. Automatic shifter problem
  176. Double Cardan Question?
  177. 88 to 95 4runner swap questions. . .
  178. Removing 3" BL question
  179. Power Seat Swap?
  180. wont start
  181. 60k mile service
  182. Headlight conversion
  183. Gurgling noise when heat is on...
  184. Snorkel/no snorkel
  185. Bench to Bucket
  186. new to '97 yota
  187. runnin 33's
  188. stud removal ideas
  189. Diagnostic codes
  190. Good toyota repair shop in/near Burnet County, TEXAS?
  191. Installing Aap
  192. CV joint work: recently replaced boots can be reused, right?
  193. 1996 T-100
  194. 95 4runner T-case ????
  195. Sealing the drivetrain?
  196. Idle Probs And Funny Noise
  197. rough idle when motor is warm
  198. Bilstein Shocks Lift Question~~~~
  199. Rim Swapping, 03 Taco to 88 4Runner
  200. P0133 & P0130 codes
  201. shackle lifts
  202. How to check fuel sending unit?
  203. Front suspension part missing?
  204. 89 4cyl pickup 22R-E Won't Start
  205. New exhaust
  206. Windshield Washer not working 1987 SR5
  207. Stump pulling: 1st gear or reverse?
  208. 2nd gen 4runner vs. pinzgauer
  209. Tacoma factory alarm
  210. i am bad at this stuff
  211. transmissions
  212. gas mileage?!?
  213. 85-86 body part compatability
  214. The 2 elect. controls behind shifter, both inoperable. Where's the problem?
  215. Heli-coil problem
  216. stupid questing :)
  217. Should i buy??
  218. Relay for fuel pump?
  219. How hot/warm should the 2 gear shifter levers get?
  220. What kind of lift for a 97 4 runner
  221. Fuel pump?
  222. Grab Handle Bolt Size
  223. 95.5 tacoma 4inch blocks ..NEED HELP
  224. how bad is spindle-itis? (safety wise)
  225. Valve Lash
  226. 04 tundra coils?
  227. Toe In Adjustment.
  228. 98 4runner SR5 body lift
  229. Need reman 3vze in Alaska
  230. Coolant Level 1982 22r
  231. tranny mount
  232. drop drag link..or hi-steer
  233. Please critique this humble newbie's maintenance strategy
  234. Replacing CV boots, what else should they do while they're in there?
  235. ifs lift question
  236. custom slider ideas
  237. junk yard head??
  238. No Reverse!!!
  239. spare tire winch problem.....help??
  240. my 1kz will not start .help needed
  241. Vacuum switching valve
  242. 1988 yota 4x4
  243. 87 Pickup 4x2 to 4x4 conversion. How difficult?
  244. Seat Problem
  245. bad Center Support Bearing on 2pc drive shaft?
  246. compatibility of toyota wheels with other makes
  247. CV axle boot replacement
  248. Suspension Suggestions -2nd gen 4runner
  249. new wheels on 4th gen
  250. amount of lift needed
