View Full Version : Newbie Tech Section
- 79 toyota 4x4 4speed to 5speed
- I can smell it! 2000 T4R coolant mystery.
- 85 4runner engine seized or my tranny or my transfer case
- anyone have experience with headgasket and shims?
- 1990 toyota pickup cel 02 sensor questions
- body work
- First Toyota
- 85 4runner 22re fuel issues
- 1999 4runner pricing
- Axle Differential Build
- Full rebuild? Or bearing?
- Will these cams for sale pass CA smog
- Problem! New 22RE Rebuild = Loss of Power.
- 3.0 problems
- newbie/build advice. what am i missing?
- Tie rods and ball joints are shot! Anything better than stock to replace them with?
- lift acessories
- New Yot! Now what...
- lift question for a v8 swap
- speeometer needle vibrates, does not bounce.
- 2000 4runner check engine light
- Driveshaft Direction?
- lower to higher
- problems with 92 22re.
- ifs lift options....
- Frame repair help
- Torsion Bar Lift
- corolla spark plug question
- Gen 1 22r idling and smog question
- changing fuel filter, depressurize fuel system?
- 1999 4Runner blown hg 170k miles need motor
- Check engine light went off and truck won't run right
- Headlights cause rise in RPM - is this normal?
- 3.4 Supercharger Rebuild Question
- 22re or 2rz?
- Front passenger side sag.
- 99 4runner limited 4x4 transmission problems
- Trans to T case Seal/Gasket
- 4x4 gears
- 1988 toyota lift ideas
- 3VZE Spark Plugs
- hard brake pedal no stopping power please help?
- Front End mystery
- new guy needs tire recommendations
- speedometer drive gear chewed up.
- fuel injectors
- can i run my fog lights without a relay
- Engine rebuild
- 81 22R acceleration problems
- 4Runner rear bumper assembly interchange
- New Toyota Owner
- 88 3L cranks ut no spark? code 14 on the CEL?
- want start when warm
- will a 1992 toyota axle shaft fit into an 84?
- Parts?
- 85 toyota please help
- rust around windshield
- Pics of 4 drop bracket and 32x11.5 Tires.
- urgent is 86 tail gate same as 80?
- High mileage maintenance
- Problem after installing BJ Spacers in 88 runner*
- 1990 4runner needs a body lift!
- 3.0v6 02 sensor in 22re
- TPS ohms reading
- What else should I replace: 22RE head gasket job
- Transmission bolts
- 3vze assembly manual
- 3.0 90 swap to 92 need help with one wiring block
- Marlin doubler...crawler gear
- extended period of time driving in 4L
- reverse lights out
- Replacing front axels
- Rear Shock Length Question. Leaf Springs. BJ Spacer and Longer Rear Shackles.
- 88 toyota,correct wheel offset?
- Oil pump removal
- Why is cylinder 1 clean and the others dirty?
- Issues with 95 4runner 3vze
- poor acceleration
- poor acceleration
- poor acceleration
- new yota and have a problem or 2
- 91 4runner sr5 manual v6 transmission problems PLEASE HELP
- Problems with 22RE! IAC? TPS? Wonky idle/dying
- Do I count? 1985 Toyota "Belair" 22re running on 3 cylinder
- 1990 4Runner just bought and needs some help
- 22re engine rebuilt
- gas expansion leaked from fuel filter, possible?
- 4wd problems
- hesetation during acceleration 3.0 v6
- Christmas Time
- aftermarket windshield trim?
- 1988 pickup ball joints
- Loud knocking noise
- 4runner 1994 and others !
- Do I need a trac bar? Video...
- Head gasket question
- smoke coming from manifold heat sheat pipe?
- cut out at high speeds
- help please!
- Group up advice, please. 2003/2004Tacoma TRD into expedition vehicle
- Carburetor question
- Any baja guys/trucks out there?
- crankshaft bolt 22re torque sorrow
- adding power
- K&N vs S&B 3VZE
- Suspension and Steering Questions About My New 2nd Gen 4Runner
- timing belt troubleshooting
- fuel filter orientation 22RE
- Idle Problems; Please help to make sure Good or Bad AFM??
- KN air filter and stalling
- Speed sensor input for GPS install
- timing belt changed. starts but wont drive?
- Show hydraulic plow guts please!
- Pinion angle help
- What plug wires to use?
- new 4runner
- work truck help, I will donate to the site!
- New Injectors
- Stock Alternator doesn't fit
- 22ret swap
- 1990 4runner suspension
- Best exhaust system for 3.0L 4runner
- Part ID Help - Ventilation Into Cyl Head?
- cluch/trans help!
- toyota hilux 2y 1.8 carbuter
- newbie question
- Charging system problems.
- What motor for mud? 1980 first gwn
- 88 pickup diagnostic jump wire
- Wiring Harness
- Turbocharged toyota
- 22re exhaust manifold questions
- Scored a muffler on felabay!
- new differentials
- I can't get my 1988 pickup out of 4wd
- heater core question
- regaering my solid axle for my swap
- 40 over bore head gasket on a 22r
- building my axles
- Low oil, but full under cap?
- frame protection
- Just wondering if these tundra rotors will work
- 1985 with 35's... gearing?
- 4runner
- '87 22r alternator question
- Interesting 4 Runner starting
- t-100 oilpan gasket leak
- easyist way to check front diff gear ratio
- whats the best gears to have running 35s???
- Missing
- Slider Box Instead of Shackles?
- removing fender flares Sequoia
- Tundra speakers with JBL
- High Idle
- Replaced head gasket, now it wont start!
- Seat Swap Question
- A few 1980 pickup parts im looking for
- 4Runner parts?
- Vacuum Port on Air Chamber (stamped 813) - should it be plugged? PICS
- 35's with a 3 in. lift
- rusty coolant after only a week
- Instrument cluster problems
- Grabbing drum brakes on a 1985 pickup
- Brake pad ??
- Idea for custom cowl induction hood
- 1990 4runner rebuild (bring Molly back to life)
- simply getting the key out
- 79-83 only what size tires do you run with stock4cyl.?
- Preparations needed to drive 4runner 400 miles.
- 93 p/up 22re, dead battery or???
- Help me ID this Tcase
- Someone Anyone, Help me out here
- 22re muffler recommandations
- 3.4 swap gearing questions?!?!
- idle speed
- Question about coolant overflow level
- 1988 4wd brake,shocks,bearing,lubrication preventative maintanence
- ebrake adjustment(s) on 06 Taco (standard)?
- electrical problems with 88 2wd 22R
- 1985 Toyota 5 speed 4x4 22r: trans
- 94 4Runner Spinning Flywheel
- Newb bought himself a hackjob SAS truck .. my plans to get it sorted out. Advice ?
- OEM Mid to late 80s-90s Toyota Pickup and 4 Runner Aluminum Wheels.
- 1986 4runner
- help me new truck needs frame repairs
- 98 4runner locker
- 94 4Runner Starts the dies
- noisey start
- Sputtering/Hesitation
- 88 22R runs lean hard to start.
- Removing Auto Wheel Hub
- Lift Kits and Exhaust
- air intake swap
- 90 SR5 fuel filter nuts
- 1986 Toyota Pickup Charge Light (12 V at + terminal)
- 94 truggy suspension
- 98 4runner RPM Gauge stopped working
- 1999 4Runner P0420 Code
- guidance on new truck
- Does my truck need to be level for some repairs?
- 87 22re w/ a340h...will an a340h from v6 fit?!?
- CNS Motors
- dual case direction needed
- starter trouble,please help!
- Superwinch vs Aisin Hubs
- ifs lift issues
- help with a suspension lift
- 88 4x4 - No, Really, Where is the diagnostic connector?
- 1990 4runner lift suggestions
- 4wd not working
- Torque Converter
- Only VSC trac light on 05 Rav4, changed gas cap
- brake light problem
- when to extend driveshafts
- 22re idle gos up and down randomly
- "Apply MP grease to THRUST PORTION of the camshaft"? Where is this specifically?
- need some shock advice
- 22re timing chain help
- need advice on suspension lifts
- 22r wont start, battery, alternator and starter are good
- '94 T100 3vze jumping speedo/noise/engine hesitation
- 2005 4Runner - Getting Whine on Acceleration
- Fuel/Air sensor test
- Driveline or brakes??
- 1984 Toyota Hilux starting issues.
- Wheel bearing Question
- 2004 Stock Taco, 2WD Mods
- Vibration and Low Humming sound in my 06 Tacoma
- Vibrations in my truck.
- Unusual problems . . .
- Anybody Had Experience w/Duplicolor Engine Paint
- rear window relay "fix" 2nd gen 4runner
- 1982 toyota 4x4 intermittent miss/stumbles on acceleration
- 88 22re wont start but cranks and no lights
- 22re swap wont start need help please!
- 1990 4runner, running rough after bottom out
- Stumped: new brakes and now a rear clunk!
- Cleaning under cowl vent/ windshield wiper arms
- Rear axle swap question
- jumping speedo needle
- Tranny and Tcase compatibility?
- 93 rear rock style bumper !!
- What do i buy?
- Fender replacement????
- Electric Problem. What to do?
- 23 Spline Input Shaft 2.28 or 4.7?
- 22RE Engine tick on Accel/Deccel
- vacuum lines
- v8 swap with 4.3 harness break light and blinker problems
- Air deflector
