Sponsored by: CARiD
changing fuel filter, depressurize fuel system?
Old Nov 24, 2012 | 01:26 PM
Jadri's Avatar
I was reading my Haynes manual on how to change the fuel filter and it says I need to depressurize the fuel system before working on it ('88 4Runner 22RE)
It says to disconnect a wire on the fuel pump with the engine running to do this. It seems like the fuel pump is pretty hard to get to, is there an easier way? A fuse maybe?
Old Nov 24, 2012 | 01:42 PM
rworegon's Avatar
I've never bothered to depressurize the system before starting. Seems to me, slowly opening the fuel lines at the fuel filter is sufficient to depressurize the system. I do open the fuel cap before starting too.
Old Nov 24, 2012 | 01:50 PM
Jadri's Avatar
Thanks for the response.. Any tips on getting to the FF? Book says its underneath the intake manifold. Do I need to remove that?
Old Nov 24, 2012 | 01:56 PM
rworegon's Avatar
Do a search....I know it is in a thread or two. I'm not a 22re guy, sorry. Lots of 22r/re guys around here though.
Old Nov 24, 2012 | 01:58 PM
Terrys87's Avatar
Disconnect the battery as fuel can drip down on starter. There is an access plate that can be removed to get to the filter a little easier. I find each truck has a different way to access it.
I can get the back bolt of the filter from over the fender in between firewall and filter. It is a tight fit. Dont need to remove the intake. Removing starter can help, but I dont remove it.
Old Nov 24, 2012 | 01:59 PM
rworegon's Avatar
And, work on a cold engine with a cold exhaust.
Old Nov 24, 2012 | 02:07 PM
Jadri's Avatar
Alright thanks for the help guys. Once I find the filter I'll disconnect the battery and put something under the FF so fuel can drip out safely
Old Nov 24, 2012 | 02:27 PM
brianh699's Avatar
Factory procedure for depressurization is to put rag on cold start injector and loosen it from intake manifold.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
nick b
Jul 11, 2015 04:38 AM
Kluch8651
Jul 9, 2015 10:39 AM
