Sponsored by: CARiD
1985 with 35's... gearing?
Old Oct 23, 2012 | 03:24 PM
gnardawg4sho's Avatar
from what i have read, there are a lot of different factors. i run 35s. arb style front bumper, plan on getting a marlin crawler rear bumper. occasional freeway driving but mostly around town and 4 wheeling. should i go with 5.29s or 4.88s? also, what should i expect to pay or do you think someone mechanically inclined could figure it out on their own?? any opinions or knowledge helps! thanks
Old Oct 23, 2012 | 03:51 PM
nothingbetter's Avatar
mis post
Old Oct 23, 2012 | 04:54 PM
rattlewagon's Avatar
5.29s. Should bring it closer to stock.
Old Oct 23, 2012 | 04:59 PM
dropzone's Avatar
Fossilized
with 5.29's and 35's my speedo is pretty dang close
Old Oct 23, 2012 | 05:41 PM
BigBluePile's Avatar
4.88's and 35's and my speedo is pretty darn close.....of course that was with my old tcase....
Old Oct 23, 2012 | 07:01 PM
Chickenman's Avatar
Do you want to be able to drive faster on the freeway or not? If not 5.29s!
Old Oct 25, 2012 | 06:44 PM
89yotapickup's Avatar
I'd vote for 4.88 for reasons stated. to do a gear swap you need a press (I use a 12ton HF), large bearing seperator, dial caliper, dial indicator with magnetic base (measuring backlash), and you will have to make a tool to adjust you carrier bearing preload.
Old Oct 25, 2012 | 07:20 PM
Tofer's Avatar
Sponsor
5.29s, buy them ready to run from tg with your choice of locker installed. Then sell your stock gears on Craigslist. Less down time, professionally set, and locked.
Old Oct 25, 2012 | 08:00 PM
Unless you happen to know a guy that can professionally setup gears...for free...
Old Oct 25, 2012 | 08:48 PM
westjohns yota's Avatar
thats how i did mine, and it wasnt much more then buying the gear, lockers and all the things to do it, i think i got 1,089 for each third off low range offroad and thats with 5.29s an detriots
Old Nov 13, 2012 | 08:58 AM
aztoyman's Avatar
I'm running a 22RE on 35's and 5.29's. My speedo reads 4 mph high according to my GPS. Plenty of power, zips around pretty good for a 4 banger.
But........I do a lot of freeway driving. 75-85 mph and it's tach'n over 3000 rpm. 4.88's would be better in this case.....in my opinion.
In your case you may be happier with the 5.29's and it gives you the option of going to bigger tires.
Old Nov 13, 2012 | 10:33 AM
EFI85's Avatar
529's with out a doubt in my opinion
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
deepmarsh
Aug 6, 2015 03:44 AM
