Sponsored by: CARiD
Anybody Had Experience w/Duplicolor Engine Paint
Old Sep 24, 2012 | 09:43 AM
wrenchtech's Avatar
I'm getting ready to rebuild a 3VZE ('88 3.0 V6). I don't want to put a lot of money into paint with hardener (two-stage). Anybody know how Duplicolor spray holds up? I'm in the North American rust belt. I want to know if it will protect my block from corrosion for a few years.
Old Sep 24, 2012 | 10:10 AM
waskillywabbit's Avatar
Worked fine on my 85. Get it clean then paint
:wabbit2:
Old Sep 24, 2012 | 10:52 AM
wrenchtech's Avatar
Thanks for the feedback. The block will be baked and blasted. Ya think brake cleaner spray would be good for final degreaser/prep?
WW, are you still refurbin' Aisin hubs? One day I'll need a set for my '84 S/A
Old Sep 24, 2012 | 11:05 AM
Yep. X2
:wabbit2:
Old Sep 24, 2012 | 03:10 PM
rokblok's Avatar
Works great so far on my engine. Header paint has been flawless as well.
Old Sep 25, 2012 | 04:08 PM
wrenchtech's Avatar
You've got an '84 extra cab with a 3RZ. Where can I see some pictures and read details? I had an '84 from 1990 till 2010. I did a 22RE swap in it.
Old Sep 25, 2012 | 07:19 PM
rokblok's Avatar
I don't have a build thread yet. I have thread with a few things I've done to it somewhere. Maybe search my name? I don't know... Lol. If you got questions, I'm happy to answer them.
Old Sep 25, 2012 | 07:34 PM
nothingbetter's Avatar
use a chemical paint stripper on the block first as it will degrease it along with take off the old paint. Get a can of self etch primer, spray that on. Then paint it with whatever you want following the topcoating times on the primer can. Your engine block doesn't get so hot that it takes special paint, use whatever you want!
Old Sep 26, 2012 | 03:36 AM
rokblok's Avatar
Really? I've seen regular, cheapo paint come right off the block when running on a dyno. Everything was prepped right. Maybe it wasn't sprayed right...?
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
toyoda8488
Jul 5, 2015 10:18 PM
