1990 4runner, running rough after bottom out
1990 4runner,3.0,auto,177,000 mi,stock,33's , no cat....bumped bottom after coming off a trail the other day, not very hard , no visible damage, got on the highway and noticed a vibration that I thought may have been my tires, ran rugged after that, changed plugs,wires,cap,rotor,fuel+air filter, oil is good, tran fluid good, took her for a run , ran better than ever, fired her up this AM, runs worse than before, shaking , stuttering, no power,never had a problem with her before, slight vibe coming from underneath,tranny, transfer,? don't see anything, only acts like this under load, is there any kind of sensor I could have knocked loose? Thanks for all the knowledge available on this site, sometimes overwhelming.
1 Post
What speed it shakes at depends on the damage. Some will only shake at 10kmph and some will only shake at 130kmph.
You could have also bent a driveshaft when it was dropped. An easy way to check is to take out either drive shaft, then go for a quick drive and see if the shake still there. That will confirm the balance of your drive shafts.
To quickly check your u-joints, get underneath and grab your drive shaft right beside the u-joint. shake it like you havn't seen your girlfriend in 3 months. If theres any play in the u-joint...change it.
Or suspension parts may have been bent, messing up your alignment and causing a shake.
As for the rough running, We need a better description on whats happening and when it happens if we are going to do anything besides throw out random advice in hope it works.
1990 4 runner,runnig rough after bottom out
Yep, was the u-joint, found out after, full tune including NGK wires and plugs, she runs super sweet, had never been touched before, I even think the MPG came up by 1 mi..
Peteyg39@hotmail.com
06-26-2015 08:15 AM
